Dec-08-2016 02:12 PM
Dec-10-2016 08:55 AM
dougrainer wrote:
Put handle in NORMAL City water position. Do you have City water at the faucets inside? This is the first thing to do. Maybe the fill inside water filter screen is clogged if you get no City Water inside. Also, this system may also have a Check Valve that is stuck. Doug
Dec-10-2016 08:49 AM
RobbieH wrote:
Problem solved over at IRV2.com. Right behind the diesel tank door is the door for the water tank. There's a valve for some reason that turns off the ability to fill the fresh tank from that connection.
I had someone mention the pliers thing, but it was for plastic valves. Mine is brass.
I could feel the valve working, so I was completely in the dark as to why it would not fill.
This isn't my first RV, just my first one this nice.
Now I have to figure out why I have amazing hot water pressure but very low cold water pressure.
That is a small water tank. Mine looks like a queen size bed mattress.
I found the drain was open, and the valve at the top left was closed and that was the problem.
Dec-09-2016 02:59 PM
Dec-09-2016 08:31 AM
Dec-09-2016 06:37 AM
Dec-08-2016 08:50 PM
Dec-08-2016 07:04 PM
George Beggs wrote:
Have you removed the cap for the fresh water tank so the air can escape?
Dec-08-2016 04:20 PM
Dec-08-2016 03:45 PM
Dec-08-2016 03:43 PM
Dec-08-2016 02:46 PM
Dec-08-2016 02:44 PM
