I suspect you have lost coolant, the five blinks of the green light means "AC PROBLEM" I suspect AC means Air Conditioner not 120 volt (but either is possible) In my case the pipes rubbing against each other where they form kind of a "Trap" just outside the compressor had gotten religion (Became holy, or holed) and let all the magic coolant out.
ADVENT makes a bolt on replacement... You need to change one molex connector on the Carrier control board (They provide in the adapt-a-kit) and.. that's all.
(This assumes ducted rooftop no heat pump, if it's not ducted, or has a heat pump, disregard the advent comment) Oh, my 15,000 BTU advent draws the same 13.5 amps the 13,500 BTU carrier drew.
I have a few spare parts (Blower, fan squirl cage, cowell, but alas not what you need.
