Jul-23-2017 09:39 AM
Aug-08-2017 05:28 PM
Aug-08-2017 07:29 AM
Aug-08-2017 12:41 AM
Aug-07-2017 07:47 PM
Aug-07-2017 04:46 PM
Aug-07-2017 10:53 AM
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Aug-07-2017 10:46 AM
OLYLEN wrote:
If memory serves your best cooling RPM is at 2200 RPM. Settle into a gear that allows the 2200 RPM then you can start playing in that RPM range with and up shift or speed up a touch to see if it stays cool.
LEN
Aug-07-2017 09:09 AM
Aug-07-2017 06:36 AM
Jul-24-2017 06:20 AM
Jul-23-2017 02:44 PM
flagstickfrank wrote:
I've driven a 300 hp CAT for 15 years and if you go up hills at full, or near full, throttle it will heat up. You have to keep a close eye on the gauge, when it starts to heat up you just downshift and slow down. My fan is direct drive and the only way to cool the engine is to bring up the revs. In some cases I'm in the truck lane but I don't overheat and we get to where we're going without a tow.
Jul-23-2017 02:37 PM
Jul-23-2017 02:06 PM
wolfe10 wrote:hostage wrote:
seeing as the rad etc is clean the only thing I can think of is the fan clutch is weak and slipping ?
Two points:
Most rear radiator coaches have direct drive fans, not clutched fans. Yes, there are a few, particularly newer ones that are clutched.
While cleaning the radiator is important, it is critical to understand the the vast majority of the blockage will be on the FRONT (toward front of coach) of the CAC (Charge Air Cooler) which can only be accessed from the front (through the bedroom or closet).
Jul-23-2017 02:00 PM
