Ceiling cleaning
Roy_Lynne
We have a Tioga with that carpet ceiling cover, stuff, and a little leak has caused a huge mess. Fixed the leak but now need to clean or replace the carpet stuff
Have you found anything to clean it with.
Has anyone removed it and put in something to replace it.
9 REPLIES 9
Skid_Row_Joe
louiskathy wrote:
Don't saturate it just fog it.
Good advise!
I made the mistake of using too much cleaner.
Roy_Lynne
Thank you all. My project of the day.
LOL Roger my camera defaulted to the year 2020 once. So I have future pictures
snowdance
We used a carpet cleaner with a hand wand and carpet stain remover and carpet cleaner. Came out like new. Did not try to do it all in one day. Some areas took several times over.
Snowdance
We spent most of our money traveling... Just wasted the rest..
Chevy 7.4 Vortex
2000 Jamboree 23b Rear Kitchen
http://www.flickr.com/photos/snowdance38
Sinecure
I have removed stains from a beige headliner from a leaking car sunroof by mixing OxyClean and water, and spraying the area with a typical "windex" type sprayer. Blot with a clean dry towel and you're done. This shouldn't fade colors like bleach will.
2013 Voltage 3600 EPIC
B&W Companion hitch / TrailAir Tri-Glide pin box
Livies_Dad
On my Tioga ceiling I have cleaned several water stains with perioxide. Took several applications but did the job. cant see where the stains were.
louiskathy
I Saved this advice from years ago... don't remember who posted it.
Ok guys this came directly from the Fleetwood factory and it works.
Mix distilled water 50% with plain old household bleach, spray it on the stained area, let it sit for maybe 1 minute them blot with a absorbent towel. 75% to 80% of the water stains will come out with the first blotting. Repeat the process again and more will come out I had to do it three and four times to get it all. Don't saturate it just fog it.
Next fill your spray bottle with just distilled water and do the spray and blot routine a couple of times to rinse out the bleach.
Finally, mix 50% white vinegar and distilled water and spray it again and blot then just fog it and leave to dry.
One other thing, be sure you wear a mask as the over spray of bleach is real tough to take and the vinegar ain't much better.
If you want to see some B4 and after photos go to picasaweb.google.com/rchonly look in "Roger Photos" - "View Files" for my file entitled "1991 American Eagle - Water Damage". Don't let the date on those photo's fool you, my camera decided to default itself back to day one and I didn't notice it until those were published. I took those in May and have just finished the restoration of the Eagle about 10 days ago. I'll put up some new photos in about a week. I found me a jewel as it has 6,011 miles on it.
You will be surprised how fast this works and pleased with the end results.
Roger
11/21/2010
Before you try painting, mix plain old Clorox bleach & distilled water in a spray bottle at a 50% solution. Spray it on leave for about 30 to 45 seconds and wipe it off with an absorbent towel if it's going to work you'll see it right away. If it works keep applying that way until the stain is gone. Once the stain is gone spray a 50/50 mix of white vinegar and distilled water and wipe off a couple of times and you will have nuetralized the bleach, finally just spray and wipe with distilled water and it should be cured.
If that doesn't work go with the paint job.
OH YEAH, WEAR A DUST MASK WHEN YOU SPRAY THAT STUFF (the bleach & the vinegar) OVERHEAD IT IS REALLY NASTY TO BREATH.
Kathy
Road_Dog
Woolite Carpet Cleaner!
path1
This is what we use. Works good but takes a long time and sometimes going over area more than once to get out some water stains if they been there for a long time. And using it over your head is a pain but still a lot better than bigger machines. Follow directions on the carpet cleaning liquid. If a little bit is OK a whole lot is better is not true for this. To many soap suds. Couple places where we didn't get dry as possible or was really dirty or stained shows up when it dried. We've had better results by following up with a regular wet dry vac, to get completely dry as possible. Also works wonders on other upholstery (chairs, sofa etc). If this thing doesn't get out your mess you have, I think it is time to replace. But would be my first choice before replacing overhead carpet. Worked for us. See link and be sure to read the reviewshttp://www.target.com/p/bissell-little-green-compact-multi-purpose-deep-cleaner/-/A-12777897?ref=tgt...
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
IAMICHABOD
My Tioga also has that carpet type stuff on it, I found that Folex did a nice job of getting rid of stains.
I just sprayed it on and Blotted it til the stain was gone.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
