โAug-27-2016 09:56 AM
โAug-27-2016 05:51 PM
โAug-27-2016 05:46 PM
smkettner wrote:Yes, same road speed, less engine rpm, due to higher ratio gearing (numerically lower), while the engine is also under load.pianotuna wrote:I believe we are talking same speed less RPM.
Then how come I use less throttle at 50 mph than at 60 mph? (and way less fuel)Jagtech wrote:
Lower engine speed equals larger throttle opening, which effectively negates any fuel savings.
โAug-27-2016 05:43 PM
โAug-27-2016 05:36 PM
โAug-27-2016 05:17 PM
โAug-27-2016 05:11 PM
โAug-27-2016 04:57 PM
Sam Spade wrote:lenr wrote:
Would be shocked if fuel savings would pay for gear change.
And I would be shocked if some layman's gut feeling turned out to be better overall that all of the mechanical engineers who designed and built the thing to start with.
If you think you MUST.....wait until you need tires anyway and get some slightly taller ones.
If you do the gears you are likely to OVER do it and the result will be worse mileage and engine and transmission strain and a MUCH bigger bill in the end than you bargained for.
โAug-27-2016 01:17 PM
โAug-27-2016 01:10 PM
smkettner wrote:
2000 rpm is pretty good for gas or is this diesel?
โAug-27-2016 12:27 PM
โAug-27-2016 12:05 PM
โAug-27-2016 11:12 AM
โAug-27-2016 11:02 AM
โAug-27-2016 10:52 AM
โAug-27-2016 10:48 AM
