Jul-26-2020 05:59 AM
Jul-27-2020 07:28 AM
Jul-26-2020 02:05 PM
RoyF wrote:
If the batteries are connected in parallel then the two positive posts are directly connected to each other, so a connection to one positive is a connection to both. The same goes for the negative posts. So connecting to the positive and negative of just one battery will charge both.
Jul-26-2020 09:48 AM
GordonThree wrote:
5 volts? Maybe you have two 6 volt batteries wired in series, not two 12 volt wired in parallel. What are the markings on the batteries?
Jul-26-2020 09:46 AM
Jul-26-2020 08:54 AM
Jul-26-2020 08:37 AM
Executive wrote:
First determine what batteries you have. 12VDC will have six caps and 6VDC will have three. AGM batteries are maintenance free batteries so there will be no caps on them. Since you indicate fluids are full you have STD or wet cell batteries. Finally, look at the batteries and let us know if the positive of one connects to the positive or negative post of the other....a google search will give you lots of info on AGM and Gel....Dennis
Jul-26-2020 08:19 AM
Jul-26-2020 08:05 AM
Jul-26-2020 07:41 AM
Jul-26-2020 07:30 AM
kemer wrote:
There are 2 batteries that run in parallel. (Positive to positive, negative to negative)
Right now, my voltage meter shows around 5.00 on each battery.
Jul-26-2020 06:55 AM
Jul-26-2020 06:39 AM
Jul-26-2020 06:29 AM
Jul-26-2020 06:28 AM
