chasis fuse block 95 winnebago adventurer
mtroger
I cannot find the CHASIS fuse block on my 95 Winnebago Adventurer. It has the fuses for my electrical steps which has quit working. I know where the fuse block is behind the tilt up instrument panel but I need the Chasis fuse block. The chasis is a 1994 Chev Workhorse.
2 REPLIES 2
23hotrodr
The fuse panel behind your flip up instrument panel is the chassis fuse panel.
The 12 volt house fuses will be in your power control center. Usually behind a drop down door with vents below and often in the kitchen area on your vintage MH. This panel contains your converter, 120 volt ac breaker panel and the 12 volt dc fuses for your house equipment. These are the main 2 fuse panels for Winne's back then. Of course, there could be other inline fuses and breakers for installed accessories.
Good luck.
2007 Itasca Suncruiser 35L
2000 Jeep Wrangler
harold1946
Make and model of chassis?
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
