chassis battery hook up 05 country coach inspire
a_j_w
Have 4 6 volt batteries on 05 country coach not sure how they are connect do i hook them in series are parallel diagram would really help had replace all 4 and took them out with making a diagram
3 REPLIES 3
wolfe10
Start by hooking up each pair of 6 VDC batteries in SERIES.
Now, you have two 12 VDC batteries.
Hook those in parallel.
Reattach wires to coach on the positive of one of your "12 VDC batteries" and negative/ground to the other.
Quite likely you have more than one wire to attach to both positive and ground.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
teddyu
Are the batteries 6V or 12V? Configuration depends on type (voltage). JM2ยข...
Ted Fulltiming in the DreamCatcher a
2008 Challenger 371PE on F53 w/ 2010 Cobalt
R'V there yet?
Mandalay_Parr
Yes, a series and parallel combination.
Just curious. Why do you ask?
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
