โAug-08-2012 02:23 PM
โDec-20-2014 04:53 PM
โDec-20-2014 09:46 AM
Snowman9000 wrote:
I would think some Class C and many Class B owners would be affected by this. I'm trying to guess what the fix is going to do to the performance, MPG, etc.
โJun-01-2014 08:45 AM
โMar-01-2014 11:27 AM
โDec-07-2013 09:09 PM
โDec-07-2013 10:56 AM
โDec-07-2013 09:44 AM
โDec-03-2013 07:41 PM
โDec-03-2013 12:06 PM
vanGogh wrote:
Thanks to all who responded. I will check tires, alignment and air bags to see if I can get a safer feeling ride at higher speeds.
Elle
โNov-27-2013 06:18 AM
tenbear wrote:Mich F wrote:
I believe for 2013 the Chevy 3500 has a GVWR of 12,300# with a GCWR of 15,800#. The Ford E350 has a GVWR of 11,500# with a GCWR of 18,500#.
My 2005, 2004 Chevy chassis, is rated by Thor as GVWR 12,300# and GCWR 17,000#. I have been towing Subarus since it was new, 3,100#-3,200#, with no problems.
โNov-27-2013 04:51 AM
โNov-26-2013 07:32 PM
Yes, those are the numbers reported by Winnebago for specs of one of their C Minnie Winnies.
The 15,800 GCWR could leave one with a very minimal selection of toads. From what I could see Forest River/Coachmen and Thor are no longer using the 3500 and that is likely the reason. The 4500 makes more sense if one wants a GM chassis.
โNov-26-2013 07:19 PM
โNov-26-2013 07:02 PM
โNov-26-2013 06:34 PM
pnichols wrote:I was just quoting from the brochure that I have for my unit in 2002. I do not know if they knew what they were talking about. They had the Chevy chassis at 12,300 GVWR and the Ford at 10,700 lbs. The only reason I wrote that was because of the comment about the Ford frame being tougher than the Chevy. That could be true today. Things do change. :BGene in NE wrote:Boy, that must have been a few years ago. I'll bet it was way back when good old one-ton dually pickups were rated only in that range, too.
The Ford E350 was at 10,700 lbs for a while.
