Mar-20-2016 04:00 PM
Apr-02-2016 08:16 AM
j-d wrote:j-d, I don't dispute your point. In fact I agree with it. I am only wondering why Ford (and maybe GM) is not equipping their RV prep package adequately with regards to stabilizer bars and shocks which are the same front bar & shocks used on a regular E250 van....last I checked a number of years ago. They have an RV prep package. They should "Prep" it right for a full-time RVing max load condition. Not for an E250 van. I was imagining Ford's thinking calling it load averaging. Maybe I should have labelled it something else.....how about "Awe Heck It's Good Enough" 🙂ron.dittmer wrote:I find "load averaging" VERY VERY VERY hard to believe. ???WHY??? Because Ford not only offers cutaway chassis, but specifically a Mobile Home Prep Package. You can search the web and find the details, but basically it deletes seats, mirrors and cab carpet. Then in adds deluxe grille/lights, cruise, power windows/locks etc. I think there's even a shortened antenna to sit under the Class C overhang. "Hey Joe! Winnebago just ordered 1000 cutaways with MOHO prep. Wonder what they'll do with those?"
If you are like me, you question why inferior parts are installed to begin with. I wonder if it has to do with "load averaging". The chassis may be equipped under the assumption that it is a delivery truck, sometimes running empty, sometimes with a partial load, and rarely loaded to max capacity by weight. But in the case of a motor home, the weight of the house and contents loads the chassis to max capacity "ALL" the time which renders those parts inferior all the time. That is why I feel the NTSB should require chassis manufactures to install heavy duty equipment on every "Made For RV" application chassis.
Apr-02-2016 07:48 AM
Apr-02-2016 05:54 AM
ericsmith32 wrote:You will learn that every improvement will help by some amount. Some more than others. In some cases it will depend on how worn out your original parts are. Given you are completely missing a rear stabilizer bar, adding a Heavy Duty Hellwig or Roadmaster, I would think that you will notice the greatest improvement thereafter.
Walmart parking lot would be better for that! I know for a fact we make it rock as you describe.
Now with the new shocks on I'm not to certain on that. Haven't tried or even drove it yet
I've found a cheaper source for the rear sway bar but the steering stabilizer will be next. On the list for next month. All upgrades seem to be around 250-300. I'm amazed just how much our cheaper RV is missing. Most class A's have everything I'm adding, even a lot of Class C's!
Apr-01-2016 04:34 AM
Apr-01-2016 03:40 AM
Mar-31-2016 04:08 PM
tenbear wrote:A rear sway bar (also called an anti-sway bar or a stabilizer bar) is easily identifiable.ericsmith32 wrote:I don't know if mine has a rear sway bar. I'm not sure if I could tell if it does. I didn't install one. In any case, there are a couple of inches of snow on the ground and it's raining, so I'm not crawling under it right now to see.
Mine didn't come with a rear sway bar. Tenbear does yours have one? Perhaps that the major issue handling wise.
Mar-25-2016 04:55 AM
Mar-24-2016 05:45 PM
Mar-24-2016 05:06 PM
Mar-24-2016 12:40 PM
Mar-24-2016 10:16 AM
Mar-24-2016 10:05 AM
Mar-24-2016 08:07 AM
Mar-23-2016 06:22 PM
Mar-22-2016 04:42 AM
