May-28-2013 05:04 AM
May-30-2013 04:30 PM
May-28-2013 05:19 PM
Ivylog wrote:
You have two ride height valves, probably on the rear axle. There is a rod with rubber connectors, check that it's still attached. If it is then slip the rubber end off and work the ride height valve back and forth and see if it will raise. Since it's already down on one side you can probably slide in from the other side and as long as you stay under the axle you'll be safe enough.
May-28-2013 04:55 PM
May-28-2013 02:34 PM
May-28-2013 06:55 AM
