Jul-22-2019 02:08 PM
Jul-23-2019 05:11 PM
Jul-23-2019 10:47 AM
Bobalooie wrote:
Man, Bigfoot is slooooooooooowwwww to respond to phone calls. So, no answer from them yet.
I "think" the GCWR is 21,000lbs and the GVWR is 14050lbs on this Bigfoot. So, that's close to 7000lbs. The horse trailer is around 6000lbs with horses and tack on board. That sounds to me like it is within spec....
Jul-23-2019 10:22 AM
Jul-23-2019 08:34 AM
DrewE wrote:akrv wrote:
If the motorhome is your on a E450 your 12000 is kilograms not pounds the motorhome is built in Canada. That would mean the hitch would be 5442 lbs and a hitch weight of 544lbs. The numbers fall in line with my E450. Your biggest problem would be overloading the rear tires. I had a two horse side by side with two quarter horses and weight 4500lbs at the scale. I would run with all tanks empty and never more than 3/4 of a tank of gas. And was 300lbs under GAWR. Good luck
I think you converted kilograms to pounds the wrong way around; a kilogram is about 2.2 pounds, so 12,000 kg is around 26,400 pounds, and up in semi truck territory.
Just because a hitch is a class IV and rated for 10,000 pounds (or whatever class it may be) doesn't mean the vehicle can tow that much.
I can get a class III hitch (or, at least, a hitch with a 2" receiver) for my Honda Fit, but that doesn't mean it could tow anywhere near a 5000 pound trailer or support anything like a 500 pound tongue weight. Honda claims it can't tow anything; in practical terms, a utility trailer of maybe 1000 to 1500 pounds or so would work out acceptably well with reasonable care. The advantage of the class III hitch over a class I or II hitch in this case is the ability to attach things like sturdier bike racks.
For towing a big trailer behind a motorhome, a super C / "toterhome" is probably the best option.
Jul-23-2019 08:29 AM
Jul-23-2019 08:21 AM
4x4van wrote:
You say that your hitch is a class IV, but then say it's rated at 12,000 lbs. Those two things don't match. A class IV is rated up to 10,000 while a class V is 12,000. In either case, that's rare for any class C, and would suggest a bit more investigation.
Also keep in mind that the difference between the rig's GVWR and GCWR is 5,950 lbs.
Jul-23-2019 07:56 AM
Jul-23-2019 07:44 AM
Jul-23-2019 05:45 AM
Jul-22-2019 09:34 PM
akrv wrote:
If the motorhome is your on a E450 your 12000 is kilograms not pounds the motorhomeis built in Canada. That would mean the hitch would be 5442 lbs and a hitch weight of 544lbs. The numbers fall in line with my E450. Your biggest problem would be overloading the rear tires. I had a two horse side by side with two quarter horses and weight 4500lbs at the scale. I would run with all tanks empty and never more than 3/4 of a tank of gas. And was 300lbs under GRAW . Good luck
Jul-22-2019 09:25 PM
Jul-22-2019 07:39 PM
Jul-22-2019 06:44 PM
Jul-22-2019 04:38 PM
