Cleaning a fantastic fan
Tom_Barb
How do you do it? Ours is getting yucky. The one over the kitchen has the fumes of fry grease in it.
chemicals, remove it, or what?
8 REPLIES 8
Tom_Barb
pfidahospud wrote:
How To video link
That's what I was looking For.. RV Geek ๐Ÿ™‚
Tom_Barb
Dennis M M wrote:
Make sure you pull the fuse for the FF before you stick your fingers in there!
There is an OFF switch. be sure it is in the OFF position.
oldchief7155
You can buy the pop on screens at camping world too.
Dennis_M_M
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'13 smart CityFlame on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
SCVJeff
BTW- Fantastic Fan sells replacement screens that snap into place... No screws, making it a lifeless easier for spur of the moment cleaning binges..
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
LynnandCarol
IAMICHABOD wrote:
Here is a hint from Fantastic Fan, after it is dry, wipe it down with a little 303 protectant, buff to a high gloss, it will minimize the amount of dust and dirt build up.
I will try this. Thanks for the hint!!
pfidahospud
IAMICHABOD
Just remove the screen by twisting it or removing the screws depending which model you have, then use a paper towel with some Windex or Simple Green on it and wipe down the blades and get the grease off, wash the screen and pop back in place.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
