Jun-16-2020 11:23 AM
Jun-23-2020 07:33 PM
Jun-23-2020 06:53 PM
FunTwoDrv wrote:
Okay, I40 at Black MT is a 5 mile 6% grade. I run in the right lane and pretty much stay with the trucks and some other RV's. Of course we hit it at 60 or so and then down to 45mph for most of the way. I do let it trail off the last half mile or so just because I don't like to push it as long as I'm not impeding traffic. So, I don't attempt to run up it, or any other long grade, at full throttle. We'm about 18.6k lbs so, below our GCWR of 20K.
No heating problems thus far and we've been from NC to WA and everywhere in between.
Cheers,
Gary
Jun-23-2020 08:04 AM
Jun-23-2020 06:44 AM
Jun-22-2020 07:27 PM
Jun-22-2020 07:04 PM
FunTwoDrv wrote:
For reference, we pull a 4500# Wrangler with a 6.0, 6sp, 32' C. running up Black Mountain on I40, our temp creeps up as you mentioned. I run with the "Tow/Haul" mode turned on and the trans does it's thing with downshifting. We are around 25mph when we reach the top. The Scangage shows water temp a touch lower than the instrument cluster by 5 or so degrees. I added another external trans cooler to aid in controlling those temperatures as we travel the Rockies as well with this setup.
Gary
Jun-22-2020 05:15 PM
Desert Captain wrote:HUH??? Have you driven I-17 from Phoenix to Flagstaff or Flagstaff to Phoenix??? I've been down to 15mph or lower behind heavy trucks when passing was impossible on that route. If you can live with the reduced speed on a hard climb and your engine and transmission is not overheating, and you're running within weight limits, YOU ARE NOT OVERLOADED AND YOUR TOAD IS JUST FINE. You do not have to fly up steep hills at 70mph.
"We are around 25mph when we reach the top."
IMHO:
If the best you can do on a 6 percent grade on the interstate is 25 mph you have waaaay too much Toad and/or not nearly enough power for the load you are expecting it to haul.
Even heavily loaded 18 wheelers do better than that.
Class C's over 30' tend to have very little payload available and adding a Toad that is very close to your max towing capability is a recipe for disaster. You may be FunTwoDrv but probably are not much fun to follow.
As always... Opinions and YMMV.
:E
Jun-22-2020 12:15 PM
Jun-22-2020 10:29 AM
Jun-22-2020 07:25 AM
Jun-17-2020 10:51 AM
Jun-17-2020 10:29 AM
Jun-17-2020 09:11 AM
bobndot wrote:Mrgunguy wrote:
I’m afraid that this will be too much and the coach will overheat when I’m 1,500 miles away from home and on the side of a mountain.
2003 ? Have you checked with a radiator shop ?
I had the same symptoms as you are having while towing even on 'not so steep' hills.
The shop pulled my radiator out and I believe they boiled it, pressure tested it and replaced it. They said it had a degree of crud inside that restricted flow.
Jun-17-2020 08:09 AM
