Coachman Concord convection microwave
DaCarmack
Hello everyone.
I have a 2005 coachmen Concord 275DS. I've seen in the paperwork I have that there was a microwave convection oven combo available as an option. Unfortunately the paperwork does not show the two model number between just a regular microwave and the combo one. The regular microwave is a Dometic. Anyone have the combo and if you don't mind looking at the model number and giving it to me please.
Thank you all
Doug
2005 Coachmen Concord 275ds
4 REPLIES 4
Second_Chance
The OEM microwaves or convection microwaves that RV manufacturers use are, for the most part, garbage. We just replaced our 30" over-the-range Furrion convection microwave with an LG. I had to switch out the lower rear bracket and drill two new holes for the top screws in the upper cabinet. It was a perfect fit from a size perspective and the quality and functions are miles ahead of the OEM Furrion. Don't get stuck trying to find what originally came in the RV - especially from that long ago.
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS, disc brakes, solar, DP windows
(Previously in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
DaCarmack
There is a model number inside, but the model number is different for the convection combo. Even the owners manual I have for the microwave doesn't show the convection in it
opnspaces
Navigator II
Navigator II
Is there a model number inside the door when it's open?
CA_Traveler
Likely a 2005 model won't be available. Search for the same physical size and mounting for a newer one.
2014 Grand Cherokee Overland
Bob
