When you look at any RV: FLOOR PLAN RULES!!!
It can be technologically exquisite, but if the flow doesn't go your way, you won't be happy with it.
I wish I could find the construction details on the HR coach. I found the floor plan for the 2011 HR Augusta 29PBD and there was a lot to like. I saw full front and rear fiberglass end caps and that's a premium feature. Why? Less parts is less seams so less leaks. An aluminum or fiberglass roof would round that out. PBD was listed as "B+" which doesn't officially exist. It's really a C, but without the cabover bed, and B+ units are often 8-ft wide instead of 8-1/2 ft, sometimes also lower.
They seem to be on Ford E450, and comparing the 2011 to 2016 chassis, you don't get much on a 2016 that the 2011 doesn't have. In 2007, Ford made big changes, so THAT chassis is nicer than 2006.
Holiday (as Tom tactfully pointed out) at least WAS a premium brand. The Forester is an upgraded version of Sunseeker, an entry level brand, both from Forest River. That does NOT make them a bad machine! We have many many members here with Sunseekers and Foresters. HR is a much lower volume outfit, but every once in awhile, one shows up, and the pictures/features are really nice.
I'd like to know the Length and Wheelbase of coaches you consider. If wheelbase is too short relative to length, rear axle can be overloaded with inadequate weight on the front axle.
If you get to the tire-kicking stage, look at the Weight Sticker (usually inside a cabinet) and see if it'll allow you to carry Who and What you want to take on your trips. Coaches with slides are inherently heavier than those without or one slide vs. three.
But DRIVE it! Ideally in a variety of conditions. Go far enough to get to a Travel Center (politically correct for Truck Stop). Pay the $10 to have it WEIGHED. Bring
Michelin's RV Tire Pressure Chart with you. Adjust Tire Pressure to the numbers on the Chart. See how it handles and tracks on the road. Obviously you want the two or four tires front and rear inflated to the same pressure. But Ford chassis is sensitive to FRONT tire pressure. It'll drive far better within a few PSI of the chart.
That 29PBD I found, has "opposing" front slides. That'll make the coach feel like it has a "great room" forward, but brings weight forward. The wheelbase has to allow for that. Coach is beautiful, but watch the weight factor. Winnebago has a 29B, design I love, but it's as heavy as most 31-footers. The empty weight of the coach from the CAT Scale, plus everything/everybody traveling, has to come out to less than 14500-lb. 5000-front and 9500-rear, max.
