โDec-22-2018 08:11 AM
โDec-27-2018 12:39 PM
โDec-26-2018 07:04 PM
D.E.Bishop wrote:
Just a thought, lay a piece of 3/4" thin wall pvc across the area behind the cabinets for future hdmi cables an tben spray on the insulation. Even one inch czrdboard tubing will work. What would be the need for replacing the cables?
โDec-26-2018 07:01 PM
MountainAir05 wrote:
I am assuming that this just started and has not been going on long term. As I stated , on our 99 ours did the same thing.
โDec-26-2018 06:45 PM
โDec-26-2018 06:34 PM
โDec-26-2018 11:16 AM
Executive wrote:
Most likely that will only get you soaked insulation. If it's condensation only air flow will keep it dry. If it's from a leak, you'll have ugly wet insulation which leads to mold.....Dennis
โDec-25-2018 10:31 AM
diplomatdon wrote:You will still need a vapor barrier. The US quit using Rock Wool in the early 1960s because of settling and moisture really affected its insulation qualities.
To anyone replacing fiberglass insulation I would recommend finding rock wool. Better R value, fireproof and waterproof. Tom/Barb if unable to find it locally make a quick trip to Canada, Home Depot or most building supplies businesses carry it. Good luck.
โDec-24-2018 05:00 PM
โDec-24-2018 10:23 AM
โDec-23-2018 01:46 PM
Tom/Barb wrote:rgatijnet1 wrote:
I had a condensation problem during the Winter in the upper front cap on my Monaco coach. The only way I corrected it was to remove the shifting fiberglass insulation and replacing it with spray on two part foam insulation.
I have thought of doing that, and still may, But I have a few wires and cables up there that may some day need replacing.
For now, I've packed the area full of fiberglass insulation, we will see how well that works.
โDec-23-2018 07:55 AM
โDec-23-2018 03:34 AM
โDec-22-2018 05:36 PM
โDec-22-2018 01:36 PM
William Willard wrote:
Check the bolts holding your air conditioner -- That`s often the cause of leaks toward the front, & elsewhere - Bill Willard
