Considering installing an electric pressure washer
holstein13
I'm considering installing this Electric Pressure Washer in my coach basement.
I'd love to hear your experiences or thoughts on this.
Is it worth it (I already own the pressure washer, so I just need to pay for install)?
It says it's rated at 140 degrees, will the Oasis water heater be too hot for it?
Do I risk scalding myself if I use it with the Oasis hot water?
How useful is it for getting bugs off the front windshield and cleaning the coach?
Is 1,450 PSI a good water pressure?
2015 Newmar King Aire 4599
2012 Ford F150 Supercrew Cab
10 REPLIES 10
Norm___Deb
I had a Karcher? and had an electrical problem. Results could have been far worse than they were. IMHO I don't trust the electrical washers and will only have a gas driven in the future. Just me.
Norm
2001 Monaco Knight 38' DP Triple Slide
2001 4WD Blazer in back
"Everything I will ever tell you will be 100% the truth, or would be 100% the truth if it actually happened."
Blaster_Man
I have a pressure washer but do not use it on the MH. If not very careful, it will drive water where it's not supposed to be, and if you have stick ons, it will loosen them.
2014 American Eagle
FIRE_UP
holstein13 wrote:
Bumpyroad wrote:
I have an electric power washer. bought a gas one to do a "real" job. what do you mean by "install"? just carry it along when you think you might need it. what's to install?
I was thinking of having the hot water plumbed to the pressure washer, the electric run to a separate outlet and the washer mounted in the basement.
That way, all I have to do is open the basement, pull out the hose and turn on the pressure washer. No hooking up necessary. No carrying a heavy pressure washer either.
I had this same idea three years ago when we purchase our present rig. I have the room and, tying it into the water system would be easy. All I'd have to do after that is, get a longer pressure hose for the nozzle.
But, I think you'll have a good thing when your done. I want it for rinsing off the coach in places like the back corner of a Walmart parking lot or, any other open, out of the way area because as all of us know, about 99.9999999% of the camp grounds out there do not allow for washing of coaches unless it's a business that details them and comes into the park. I've carried my little Karcher 1200 psi unit for about that long and have used it several times. The water pump keeps up with it just fine.
It will run off the inverter but, most of the time, when we're in the corner of parking lot or, even out at a rest stop where there's no one else for me to bother, I'll run the generator to power it up. It really works slick. I use maybe, 5-8 gallons of water for the whole coach.
So, OP, I think you've got a good plan. Not sure you need the hot water. The pressure side will work just fine for you. Your choice.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
holstein13
hershey wrote:
I would ask? Are you a fultimer or just a weekend/vac RVer? If fulltimer, then perhaps I guess I could justify the bulk and weight of the unit, but if not, I'd leave it at home and just do the cleanup you think you need a pressure washer for then. BTW: I've never used a pressure washer on my MH in 9 years of fulltiming except: the one at a car wash to clean the radiator. It took me 7 years to give up the basement space for a small but efficient air compressor ๐Ÿ™‚
I'll be full-timing and there is a lot of room in the basement storage area.
hershey
hershey - albuquerque, nm
Someday Finally Got Here
My wife does all the driving - I just get to hold the steering wheel.
Face Book Group: All About RVing and We Fly RC's
Expedition - Chevy Equinox
holstein13
Dick_B wrote:
My pressure washer doesn't get the bugs off. I end up having to scrape them off with Soft Soap with bleach. IMHO carrying a heavy pressure washer around all the time has no up side.
Thanks, that's exactly what I wanted to now. You may have just saved me a bunch of time and some money.
Dick_B
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
holstein13
Golden_HVAC
Hi,
In the kitchen at my work, they have a 'installed' pressure washer to do the floors. It is only rated for cold water, and there is a nearby sink with the typical hot and cold faucet handles, but the hot valve is removed. You could put in a hot and cold faucet, then turn on a mixture of hot and cold going to the pressure washer.
1400 PSI should be plenty of pressure. Your water pump should provide enough flow to the pressure washer. This should work fine to get off the bugs and stuff, without enough power to wash away the graphics (unless you get to close, so be careful).
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
Bumpyroad
bumpy
