Older motorhomes up until the late 80's had exterior siding of corrugated sheeting. You know like on a 1985 Chieftain or Pace Arrow? Is that a corrugated aluminum? Or is it fiberglass? One thing I've noticed is that it doesn't seem to delaminate, and some old ones still have a nice shine! Also what is directly under that exterior sheeting? A layer of plywood, or does the sheeting mount directly to the framework?
I'm just asking because every now and then I see an older 80's class A for $5,000 to $7,000, and some of them look very clean and solid. It would be a cheap way to get started in RV's. Plus I love those old Chieftains because they made them in short models. Those 22' - 24' models are just awesome, they're like a huge Vanagon, and I bet you could fit one in a parking space.
Older class C's are an option too, but I just don't see how those cabover sleepers could stay leak free over 15 to 20 years. An old class A just seems like a simpler and better design.
I might be needing something fairly soon too. I just got hired as city bus driver in Phoenix. It's 5 days a week, and the bus compound is 25 miles away. And being a new driver I might get stuck with the 3:30am shift. So I'm thinking the way to go would be just park an RV in their parking lot (or in a dirt lot nearby), and spend a few days out at a time.
I sure wish I had the money for a down payment on a Roadtrek, that would be perfect. But even old ones go for a minimum of $15,000. I need a solution that I can have quickly and for cheap. A travel trailer would just be too long with my Grand Marquis towing it.
I even thought of just getting a cargo van. I could build it up as I get paid...insulation, interior paneling, AC unit, small generator. But eventually I'd need a basic plumbing system which I've been trying to piece together in my head. You see your blackwater tank mounts underneath the van, with the toilet above it. You have to vent the BW tank, I was thinking an easy solution is just run a pipe horizantilly off the tank, curve it around the rear or side of the van, and just run it up a few feet. I don't think you'd have to run it all way to the roof. For a shower, I just need a water collection pan on the floor with a drain going through the floor, or maybe a small greywater tank. I'll need some sort of water heater, and a freshwater tank that can just go inside the van. Valterra makes all the fittings and valves for this stuff. Sure it would be alot of work, but you take your time, one project at a time. But I'd end up with a totally self contained van, that I could park anywhere, for a lot less than a $100,000 Roadtrek.
My mind is all over the place as you can see. If you all have any suggestions let me know, thanks.
