Cost of fixing fogged windows
Bucky1320
I have a couple fogged side glass panes in my coach. I am a die hard do it yourselfer, so any way that I can do that is best for me. But if I need to send them in, that is doable. What kind of methods or costs have you experienced?
1999 Harney Renegade
Mostly used for overnights at the drag strip.
26 REPLIES 26
Bucky1320
10forty2 wrote:
Bucky....I have one window (driver's side fixed panel) that is fogged and after an exhaustive research on repair vs replace, I am replacing. Mine is an Atwood. I called Atwood directly and spoke to a super nice representative. Once we determined which replacement window I actually needed, I ordered the replacement and am into the new window for $150 plus shipping. Most DIY repair kits I found were $250+. Most repair places wanted $275+ and I would have had to send the the window for repair or drive the coach to them. My recommendation is to call the manufacturer and see what a replacement costs vs the DIY project. I never would have thought that it would be cheaper to get a new window than to repair it and use your own glass, but in my case it is! Good Luck!
Where does one look to find out who supplied the windows?
Bucky1320
Well that is good to know. I will check it out. But then Monaco said they don't have much in the way of info for the Harney Motorcoaches. Hopefully it is just like the ones put in others. The first one I want to do is the door window up front. (pusher with frontward door) Then the driver's window.
10forty2
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
Bucky1320
I like it!
Community Alumni
Not applicable
GRonken wrote:
You may be interested in this:
Window Repair
I bought a kit from Dave he was very helpful. I have now done 4 windows.....it's an all day process you will need help on the larger windows....and use gloves and wear old clothes....that black sealer gets all over and you won't get it off. FYI
GRonken
Window Repair
Glenn & Marcie
2003 38' Monaco Diplomat | 2001 Chevy 1500 Silverado Dinghy
F1 | D3 | HN7000S | 83W | WRT54GC
Sprint Air Card | KR1 Router |Wilson Wireless Amplifier
Retired Firefighter / Arson Investigator
911 we shall NEVER forget!
See Where We Are
Bucky1320
rgatijnet1 wrote:
Since we don't know where you are located, it is hard to tell you what repairing the windows will cost. I know of one place that charges about $250/window and has a place with full hook-ups for you to stay while they remove, repair, and replace your windows with a lifetime warranty. To many it is just not worth the hassle to try to save a few bucks, especially if you are talking about windows that are difficult to remove.
Northwest Illinois. I did mention being a die hard do-it-yourselfer right?
rgatijnet1
fcooper
Go here
irv2 files section
and download the file titled "fogged window repair"
and you'll see how I did one repair. It's not hard, but time consuming.
Fred
Fred & Vicki
St. Augustine, Florida
2oldman
Bucky1320 wrote:
It seems like my searches are often less effective than those that others do.
It does take practice. Use Advanced search, fewer words, and not Exact matches. For this subject, I'd probably just look for 'fogged', and see what that returns.
Google is an absolute master at this. Where I'm really blown away is in their Map searches. Address parsing is no easy job - I used to do that for a living. It's very challenging.
Bucky1320
It seems like my searches are often less effective than those that others do. That is much better than what I came up with . Thank you !
Executive45
I did the search for you. Click below and read on....Dennis
Clicky
