Feb-16-2016 01:38 PM
Feb-19-2016 08:24 AM
rgatijnet1 wrote:SarahLichtman wrote:
If there's an issue with either tire, the temperature is going to go up, so you'll know. The temperature is accurate within 1 degree. Any sudden changes or significant changes will alert you.
If you have the Crossfire and ONE TPMS and one tire has a leak, what indications will you get with the TPMS monitor?
Will it be enough that it will trigger a high temperature or low pressure signal, or will the change be so minor that an alarm will not go off as it would with a standard TPMS system?
Feb-19-2016 07:57 AM
Feb-18-2016 05:57 AM
Feb-18-2016 05:34 AM
Feb-18-2016 04:43 AM
Feb-18-2016 04:40 AM
Feb-17-2016 01:34 PM
ldm468 wrote:rgatijnet1 wrote:
Doesn't Crossfire have a valve that prevents one bad tire from taking the air from the good tire? Would that mean that if one tire deflated, the air pressure at the single valve would stay constant or equal to the good tire. If that is the case, then I'm guessing that the TPMS would not alert you if one tire deflated.
rgatijnet1:
You have raised a valid concern with Crossfires and a TPMS. I have a friend who had a Crossfire setup with a single tire pressure sender for his TPMS. His inner dual lost pressure, the Crossfire maintained the pressure on his outer dual, TPMS did not indicate a low pressure situation and eventually the inner dual started to burn. Fortunately the fire was caught in time and the coach was able to be repaired. He now has Crossfires with two TPMS sensors.
Feb-17-2016 01:00 PM
Feb-17-2016 03:13 AM
Feb-16-2016 07:00 PM
Feb-16-2016 03:42 PM
Feb-16-2016 03:31 PM
Feb-16-2016 03:21 PM
Feb-16-2016 03:18 PM
