โApr-13-2017 06:41 PM
โApr-18-2017 01:04 PM
GTMADNS wrote:
Just turned dash ac on this past weekend. It blows cool but not cold like it used to. Is it easy to charge yourself? This is a 2006 coachman cross country. Let me know your thoughts. Thanks
โApr-18-2017 09:54 AM
crasster wrote:
Really - while you can DIY recharge, it is BEST if you can put the system under a deep vacuum then charge. It's the proper way to get all the air out so there is more pure 134a.
โApr-18-2017 08:47 AM
Groover wrote:
Is mine the only one that has a sight glass for checking the freon? That makes it a lot easier to know when you have enough freon in the system. I wish that all AC systems had one.
โApr-18-2017 05:07 AM
โApr-17-2017 04:13 AM
RVER wrote:
I have a question related to this question. I have a gas engine, 2003 in Newmar Mountainair on Vortec engine and first time I have driven it in weather warm, enough to put A/C on in dash, NO cold air, air does circulate through dash but not cold or cool really. I bought this used of course so one thing after another but does it sound like a charge will do it? I do not want to spend lots of money to replace the system but would like to travel with A/C if possible from the dash. IF really hot I guess I could fire up the generator and run house A/C but prefer not to. ALL THOUGHTS WELCOME.
โApr-16-2017 10:24 AM
โApr-16-2017 09:57 AM
โApr-15-2017 01:46 PM
โApr-15-2017 12:38 PM
โApr-15-2017 12:19 PM
โApr-14-2017 05:25 PM
Really, How is air going to get into a system that is still cooling, but not as cold as normal... is still pressurized and has enough freon in the system to work somewhat? Even while working the low pressure side will have 60+ psi in it... how is air going to get in???
Bingo. HOW can air get into a pressurized system? IF the system has been open to the atmosphere, then yes, find the leak, then Vacuum and charge. Vacuum can also let you know if the system has a large leak. Small leaks that happen under pressure, a Vacuum test rarely is accurate. Now, HOW is a novice supposed to know how much 134a to install? Unless you have your gauges connected and do a digital temp at closest outlet to the evaporator, you will have a hard time getting it filled correctly. BTW, SMALL leaks will not cause Oil loss. TOO MUCH 134a is as bad as too little. Too much and the system will not cool correctly just like too little. A TEST for posters. HOW much 134a(lbs) do you think a average Diesel RV motorhome takes? Doug
A diesel pusher about 3-4 lbs
โApr-14-2017 05:23 PM
If the system is still pressurized then who cares how much freon the system holds? All you really need is a thermometer. Placed in the outlet of one of the ducts, add freon slowly until the temperature drops to it's lowest and starts to go back up. As soon as that happens, you stop. You are right, too much is as bad as not enough so you add for the lowest temp reading.
Now this is not scientific and is not how a tech would do it but for a NOVICE, it will work just fine and probably save them a lot of money.
โApr-14-2017 04:44 PM
