Jun-08-2013 06:42 AM
Sep-16-2013 06:22 PM
Sep-16-2013 05:40 PM
Sep-09-2013 10:18 PM
dougrainer wrote:Groover wrote:
Automotive air conditioners use a cool-reheat system where the air is cooled by the air conditioner and then warmed to a comfortable temp if full cooling is not required. It can even be heated to an elevated temp for de-fogging the windshield. If the reheat function is not shutting off properly it can make your airconditioner useless. Turn your system to "Vent" and the temp all the way down and see if the output air is warmer than the air coming in. If so, you have a heater control problem. Some Fords have a valve in the hot water line supplying the heater that is supposed to shut when no heat is asked for. If that valve leaks your air will be warmed somewhat, how much depends on the leak rate. My father had a Ranger with that problem new. The dealer's mechanics had no clue how the system worked or what that valve did. He finally replaced the valve himself and solved the same symptons that you are describing.
Good Luck.
ALL CORRECT. BUT, NOT for RV motorhome systems. Motorhome systems have no such blend door system like Automotive systems. Yes, if the Hot water shut off is seeping or not closing, the AC will not cool but when that happens on a motorhome system, the air output will be over 100 degrees and higher. Doug
Sep-09-2013 04:44 PM
rgatijnet1 wrote:
If the air coming out of your dash Ac ducts is not cool enough, the first thing I would check is whether or not you have a leaky heater control valve. If even a slight amount of coolant leaks past that valve it will cause the heater coils to get hot and raise the temperature of the air blowing into the coach. The adjustable heater valves are known for leaking so you may want to just add a cut-off valve in the syetem to stop water circulation during the months when you need AC.
Sep-09-2013 02:41 PM
Sep-09-2013 02:29 PM
Sep-09-2013 11:02 AM
Sep-08-2013 06:38 PM
topflite51 wrote:
It is my understanding that the dash air in the MH was never intended to cool the entire coach while traveling. It is intended for the driver and front passenger. If it is working properly it should blow approximately 50degs when the ambient temperature is 70. On my F53 I set the fan to high, the temp to its lowest setting and press the recirc and vent buttons. I have driven considerable miles with the outside ambient temperatures are in excess of 100 degrees and I have yet to be uncomfortable, heck my wife even closes one of the vents blowing on her as she feels it is too cold. I have never ran the coach AC's while driving. I would not hesitate to do so if I were the least bit uncomfortable.
Sep-08-2013 06:09 PM
Sep-08-2013 10:30 AM
Sep-08-2013 09:44 AM
Sep-07-2013 11:09 AM
Sep-06-2013 11:51 PM
Sep-05-2013 09:06 PM
phnguyk wrote:dougrainer wrote:Mr.Mark wrote:
I might be mistaken but A/C is A/C whether it's in a class A diesel or gas unit, right? We can run the dash A/C up to about 95 degrees outside. After a prolong period of that temp, the rear starts to warm up from the engine heat.
Anything over that temp I'll crank up the genny and run all three air conditioners. It's nice to arrive at our destination with the interior cooled off on a hot day.
MM.
Yes, you are mistaken. Rear Engine Diesel will get colder than a Gas engine front. The reason is the gas engine heat of the forward compartment and the fact that the Condenser FOR the AC is installed in front of the Gas Engine Radiator and Gas engines run hotter than Diesels. Also, the Condenser for most Diesel's are separate from the radiator and even if part of the radiator, the Diesel runs cooler and the ability for a Condenser to remove the heat from the AC coolant and the better it does that is a big factor in how cold a Dash AC will get. Doug
That's the craziest thing I've read in a while. Diesels run hotter, that's just how they run. My v10 never goes over 170, I'm sure your diesel is running hotter than that. The only reason your diesel gets colder has to do with the physical size of the components.
OP, you should see anywhere from 55-65 degrees right at the vent regardless of exterior temperature, put a thermometer in a vent. Any higher and there's a problem, freon, leak but something. Common problem on the f53 is the heater hose valve not shutting completely, google it, replace with a manual valve shut it in summer open it in winter.
One way to troubleshoot it is, does your fan speed change when switching from a/c to max a/c?
