Dead Chassis Batteries
plootsa
HI
I stared my 2013 Berkshire 2 weeks ago after it sat for a month no problems.I tried to start it today every thing is dead the batteries house and chassis are a little low on voltage.After gettting the generator running by jumpering it i tried starting the engine and it would shut the generator off.I tried using the aux battery and that would shut the generator down also,I need some suggestions on this wierd problem.
Thank you
Greg
3 REPLIES 3
FIRE_UP
Greg,
I don't know much about your year/model coach. So, I don't know if it's got Chassis battery charging capability while being plugged into shore power or not. And, you don't say whether you're plugged in or not. I'm assuming you're not. As you most likely know, there is "parasitic" loads on chassis batteries. Things like radio memories, Gas detectors, Engine and transmission ECMs use a tiny bit to hold memories of data and more.
I don't even know if your coach is a diesel or gas. Do you know if you have chassis battery charging capability when on shore power? Winne and Itasca didn't prior to early '06. After that, the factory started installing the infamous "Trik-L-Start", chassis battery charging system. Many have purchased that same system for installation on previous years of Winne and Itascas as well as other model coaches of both gas and, diesel.
But, all this really pertains to shore power. If you don't have or, cannot get shore power while your coach is in storage, then, other measures have to be taken. One, if you don't have "Battery Disconnect" switching, for either set of batteries, then, I might thing about getting some installed. If installed correctly, they an eliminate all your battery drain while in storage.
Now, another thing here. Are you sure you've got all items, i.e. lights, compartment lights, radios, bathroom fans, ANYTHING, turned off before leaving the coach in storage?
A small but, fairly accurate test to see if there's anything on or, a possible draw on the system would be to, remove the negative battery cable from the chassis battery, and, install (in line) a 12V test light between the cable and the negative post. If that light lights up, something's on or, there's a draw someplace in the chassis battery system. If it doesn't you're still not out of the woods. If you put a VOM in between those two items and it reads ANY voltage, you're experiencing a smaller draw than what would be needed to light up a test light.
But, the next time you go out to run the coach, as has been stated, run it for at least 20 to thirty minutes, preferably at about 60 mph so the charge rate is as high as possible and, for as long of duration as you can tolerate. That will assure you have a good state of charge prior to shut down at the storage yard. Let us know what you find out will you?
Scott
Scott and Karla
SDFD RETIRED
KI60ND
mscamping
Is it plugged into electric when it's setting? If not, you may need to use your battery disconnects so they don't have any parasitic load draining them.. Also you probably didn't let it run long enough before when you started it.. It should be taken out on the road and run for at lease 20 mile before shutting it down.. That way all systems get to come up to working temps..
If you're going to let it set that long I would get electric to it to keep the house batteries charged.. You will also need something like the "Trickle-Start" to keep the chassis batteries up, because they won't be charged by the inverter, unless it is set-up from the factory to do so.. Mike Mathews..
2003 Holiday Rambler Neptune 36 PBD - ISB 300 Cummins- Allison MH2000 5 speed
2013 Equinox w/Blue Ox Aventa II & SMI Stay-n-Play Duo
FMCA 331658 HRRVC 105155 Chapter - 57- Good Sam Life Member - Coach Net - 3/4 timers
Mike & Sharon
Old-Biscuit
Generator hasn't run long enough to charge batteries so it shuts down when you attempt to start engine etc.
Leaving gen running for a couple of hours to get a better charge on batteries.
