Diesel engine power
Hpymils
Is a 300hp diesel sufficient for a 36/37 foot motor home? Will a 300hp lug down on hills?
20 REPLIES 20
tinkerer
My C7 Cat doesn't like to shift down until about 1600 rpms. I don't know if you would call that lugging.
Peralko
How fast you go up a hill is solely a function of the HP at the rear wheels and the weight of the motorhome.
Peralko
USAF Retired
2000 Prevost Marathon H3-45
2006 Nissan Maxima
wallynm
Depends on your definition of "lug down"
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
wolfe10
Actually HP alone does not answer the question.
There are Cummins B's with 300 HP and 6XX lb-ft torque
There are Cat 3126's with 300 HP and 860 lb-ft torque
There are Cummins C's with 300 HP and 960 lb-ft of torque
They are NOT the same.
The other part of the equation is loaded coach weight with toad.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Mr_Mark1
The answer could be yes or no, how much does the motorhome weigh?
We have a 42 ft. motorhome with a 425 Cummins, weigh just over 40,000 lbs. and we go slow up steep inclines. We always make it over. Our Cummins has 1,200 lb. ft. of torque.
Our new coach will weigh 54,000 lbs, 500 hp Volvo with 1,750 lb. ft. of torque. On the test drive, I did slow on a long grade but not as slow as our current coach. Torque is what moves a diesel.
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
UsualSuspect
DP's like gassers are not set up to run a 1/4 mile and be at the top of the time trials. My BIL has a 300 HP Cat in a 39 footer, he slows down on long steep hills, but I also do with 350 HP. A Buddy has a 500 HP DP, he also slows down. None of them lug, they will downshift on their own. I guess the questions is, will it be the slowest on the hill, no, will it be the fastest, no, it will be somewhere between the slowest and the fastest.
2007 Fleetwood Excursion 40E Cat C7 350 HP
2007 Chev 2500HD D/A Long bed CC (Yes, it is my TOAD :B)
2011 Toyota Tundra
2013 Jeep Wrangler Unlimited Sahara (Backup towed)
Gone but not forgotten, 2008 Jayco 299 RLS
