Nov-07-2017 11:58 AM
Nov-09-2017 11:30 AM
gutfelt wrote:gsander1 wrote:
Both the 10 KW and 12.5 KW Onans are 120/240.
so both are two 120V line 50 amp just the same as shore power
John your good to go
Volts
120/240
Amps
104 / 52
Nov-09-2017 11:24 AM
Nov-09-2017 07:13 AM
Nov-09-2017 06:13 AM
Nov-08-2017 05:02 PM
gutfelt wrote:John & Angela wrote:gutfelt wrote:
does a 12K unit have a 50 amp feed (4 wire) or 30 (3 wire)like a 8K?? if it has a 50 amp feed just like the shore power you could tap in to the system fairly easy
if its the same as a 30amp 8K you wont get 240V nohow
Thats the kind of thing I would like to find out BEFORE we start working on this. I have heard various versions of this. I need 240 volts to make it work the way he wants or he'll be stuck with essentially what I have (120) but at higher current. EVSE's will run fine on 120 but most have a 12 amp pilot signal to the car when running on 120. There are some that send a 32 amp pilot to the car on 120 but obviously it is still half the speed of 32 amps at 240. I need somebody to measure across the breakers on a coach with a 12K Onan. Takers??
John
Like I suggested if the 12K has two 120V( hot) outputs like a 50 amp shore power has You can get your 240 if It only has one like a 30 amp system then you can not
Nov-08-2017 12:39 PM
Nov-08-2017 09:34 AM
Nov-08-2017 08:02 AM
Nov-08-2017 08:00 AM
Bud
USAF Retired
Pace Arrow
Nov-08-2017 07:32 AM
Nov-08-2017 07:29 AM
Nov-08-2017 06:43 AM
Nov-08-2017 04:10 AM
Nov-07-2017 03:22 PM
enblethen wrote:
Look for a junction box between the genset and the rig's wiring to transfer switch. This is commonly at the rig's end of the flexible conduit.
You could tap at this location. You would need a circuit breaker to protect the receptacle then run to EVSE receptacle.
This should be a 120/240 four wire circuit.
