Does it matter?
Snomas
Does it matter if I get my 2006 Winnebago 29H alignment before I put on sway bars or should I wait?
I get a little wander above 50 mph. I do have a steering arm already installed!
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
10 REPLIES 10
DougE
Just so you'll know, twin I-beam Ford suspensions of certain years are particularly disposed to wandering. They require an aftermarket offset bushing in the upper kingpin to get more than the factory caster (non-adjustable). Some have reduced/controlled, but have not cured the problem, by installing a steering stabilizer.
Currently Between RVs
DougE
Camber is more important to get even tire wear across the tread. Caster is what keeps the wheels on shopping carts tracking straight ahead. (They have no camber.)
Grit_dog
Navigator
Navigator
Snomas wrote:
wolfe10 wrote:
DougE wrote:
Sway bar doesn't impact alignment and may help sway issue slightly. Guess you replaced idler arm (steering arm?) due to wear? Have your alignment shop set the caster close to the maximum spec.
All good advice.
I thought It was the camber +5 degrees that would heal the wander problem?
Nope camber should be 000.
Snomas
wolfe10 wrote:
All good advice.
Grit_dog
Navigator
Navigator
Doesn't matter. Sway bar does not and cannot affect steering alignment.
pianotuna
Nomad III
Nomad III
Alignment is last in the chain.
Regards, Don
wolfe10
All good advice.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
DougE
Snomas
Diamond c wrote:
I would wait till I had everything done that I was going to do to the front end, then align it last.
Thatโ€™s my thought also, thx for the input,
Diamond_c
