Dometic power awning constant Boop-Boop-Boop. Help please
rubycreekted
I am camping beside a 2006 vintage coach with subject awning and symptom. The ladies do not have a owners manual. It has a box about 6 inch by 5 inch with a rocker switch that says in-out or up-down. I took the cover off this box and checked the fuse under the cover. The beeping stopped when the fuse was removed but started again as soon as I put the fuse back in. Can anyone please tell me what the beeping is trying to tell us and what may be the problem. THANKS, TED
6 REPLIES 6
BigBlockTank
btilfan wrote:
2006 is vintage?
EXACTLY what I thought. Mine is ancient, it's 3 years older than that. Thanks for the reminder, that I'm old, retired, and broke....
hahahaha
btilfan
2006 is vintage?
2007 Damon Astoria Pacifica
My next hobby.
rubycreekted
Jesse_C wrote:
Did you see a toggle switch on the black control box for the wind sensor? If so, turn it off, the beeping should stop.
No I didn't know about the switch. I will check tomorrow. THANKS ALL,, TED
cyntdon2010
wow! It took only 22 mins to solve his problem..
I like this web site.
2010 lacrosse T.T 318 bhs 34 ft,blue ox-tow bar,2005 FORD F-150 larait super crew,Firestone ready rite-air bags lift kit
dougrainer
The beeping is an indication that there is a LOSS of communication between the control box and the Wind sensor. As he stated, on the side of the box is a phone type cable and the toggle switch. Turn the toggle OFF and the beeping should stop. Doug
Jesse_C
Jess, Jane & 3 Pups: Max,Munchkin & McGee
2004 Winnebago Adventurer 38R
2013 Ford Focus Toad
