dumb jack question
klm
Good morning
I have hwh jacks on a Freightliner Newmar. Generally retracting the jacks is part of our departure routine. The engine is running, airEd up, etc. But can you retract the jacks without all that? Just hit store? I'm thinking yes, but would like to have the input from you. Thanks.
'02 KOUNTRY STAR DP
2012 HONDA FIT "PUMPKINMOBILE"
GILLIGAN- 1ST MATE CAT - 3 HR TOUR
6 REPLIES 6
siggyd777
On my 2011 Dutch Star,4020, the jacks will not come up when the engine
is running.(electrical lock out!) This is normal.
Siggy
Happy Trails
Siggy & Ursula
2011 Dutch Star 4020,ISL 400,Compr.brake,FTL XCR,IFS
Allison MH3000
2015 Jeep Cherokee,4x4 Active Drive II,V6 , Brake Buddy,Roadmaster Sterling,
Camping since 1975 Pop-Up,1986 22Ft.TT,1999 Gas MH,2005 KSDP,
2011 DSDP,FMCA 368283
hipower
We have a Newmar on a Spartan chassis and I retract the jacks before starting the engine and airing up. Actually do it on the accessory setting on the key since that doesn't activate the blaring alarm while it sits there for several minutes retracting the jacks.
I usually spend the few minutes waiting for the jacks to store outside double checking all of the compartment doors and making sure the toad is secure, having a last smoke, etc.
klm
OP here. Yes, we will be bringing in the slides prior to retracting jacks. Just don't want to start up engine for the sole reason of bringing up the jacks. Did check our HWH manual and couldn't find an answer. We've been rving for ages, but not very mechanical smart - and any variation of what we do know - is a head scratcher.
'02 KOUNTRY STAR DP
Valkyriebush
holstein13 wrote:
At a minimum, I'd want to retract my slides first just in case the ground isn't even. But after that, I don't see why not. The coach will come down on empty air bags, but it does that anyway when you first dump the air.
X-2
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
rockylarson
I think for most the answer is yes. HWH would refer you to your models specific operating manual.
Your situation may be addressed in their FAQ's:HWH FAQ's
Jan and Rocky
Volunteers for USFWS. 29 refuges with 9300 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
holstein13
2015 Newmar King Aire 4599
2012 Ford F150 Supercrew Cab
