Jul-19-2014 05:40 PM
Nov-14-2014 10:30 AM
Nov-14-2014 10:12 AM
divebobber wrote:
Thanks for the tips. By the way, would it be possible to put another model fridge in there? Something with an electronic ignition feature? What do you think?
Nov-13-2014 10:57 PM
Nov-13-2014 10:49 PM
divebobber wrote:
Thanks, Brian. I'll check it out. Bob
Nov-13-2014 10:31 PM
Nov-13-2014 07:08 PM
Nov-13-2014 01:00 PM
Nov-13-2014 06:43 AM
ronfisherman wrote:Yes, it was tested when I installed it. Was just curious if anyone had ever seen it actually shut a fridge down. From the other post, it appears it does and will. I have to make a note to check it when I am parked far off level.Pirate wrote:
Has anyone actually ever had this unit do what it is supposed to do? I have had mine installed for almost a year and have yet to hear it alarm once no matter how uneven the rv was.
Saw this thread awhile back.
ARP may have saved my fridge
Nov-13-2014 01:08 AM
Nov-12-2014 07:59 PM
Nov-12-2014 05:30 PM
Dutch_12078 wrote:No but I will. I did wire mine up with a light and alarm.Pirate wrote:
I haven't seen any indication that the ARPrv has an audible alarm. Have you checked the log for any activations?
Nov-12-2014 04:14 PM
Nov-12-2014 03:51 PM
Nov-09-2014 05:04 AM
divebobber wrote:
"The ARP controls power to the control board. If you fridge does not have a control board the ARP will not work. Check out link above for installation of the ARP."
Thanks for your reply, but the following is the response I got from an ARP representative. Apparently I can use the device. It will turn the burner off in the event of overheating, however, I would have to relight it manually.
"Hi Bob,
Good question, I have a similar fridge in my camper. The ARP Control can control a relay that works with a Norcold thermocouple interrupt adaptor which is placed inline with your Dometic burner thermocouple. When the ARP senses an overheat situation, it turns off the heat by activation of the relay. I have drawings in the user manual found at the following address:
http://www.arprv.com/rv-refrigerator-manuals.html
I plan to post drawings on my website as soon as I can regarding this installation.
The ARP can not restart the fridge as you pointed out, you would have to preform this task your self. Would you rather the fridge turns off or destroys it self? The fridge does not cool when it is off level, thus without the ARP you fridge just fails, with the ARP your fridge turns off and you may have to toss some food, not the food and the fridge :)"
