Electrical outlets
helen_s
2001 Fleetwood Discovery 30 amp. Everything was working fine. Went out next day and all the electrical outlets that are next to the refrigerator,microwave and front tv have no power to them. Any ideas! Checked fuses put in new circuit breaker and I have taken apart all the outlets.
6 REPLIES 6
jauguston
Good advice here. Either a GFI has tripped-sometimes for no explainable reason or one of probably two little breakers has popped in the converter/inverter. I have had both happen for no reason that could be explained. If you have a inverter/converter combination unit like my Magnum or others there is usually two 15a circuits that go through the inverter and there are breakers for those circuits on the inverter. One of those circuits do what you have lost.
My tripped GFI was in the bathroom and had a little red light on that indicated it was tripped.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
enblethen
Check the small circuit breaker on the inverter. It could be either white or red.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
the_bear_II
Is any one of them a GFI oulet or are they connected to a GFI circuit breaker in the electrical panel. The GFIs are engineered to trip if something strange hppens on the circuit. Occaisionally mine will trip on the circuit the frig and the microwave plus an outside outlet are on. Probably due to moisture.
Anyway I just reset the breaker in the electrical panel and power is restored.
JerryofWV
One of the outlets should be a GFCI outlet. It will have a reset button.
It controls all outlets in its circuit. Sounds like that is it.
Jerry & Dee Dee Pauley
2005 Monaco Monarch SE, Workhorse, Falcon II tow bar, ReadyBrake, 2012 Jeep Liberty Toad
The happiest people don't necessarily have the best of everything. They just make the best of everything they have.
ScottG
Bad or tripped GFCI someplace. I would check the bathroom first but it could be many places.
rgatijnet1
Reset the circuit breakers on the inverter itself. These are outside on the inverter case. There could also be an outside GFI outlet that needs to be reset.
