Engine air
Old_Blue
What I can not understand is why would the engine a/c work on Sunday and 6 days later blow warm air? It has worked great for the last year since it was worked on by a a/c mobile unit repairman with things replaced and recharged but in just 6 days nothing...what am I missing....2007 Holiday Rambler 36ft. PDQ.
Bill
Bill
36 Holiday Rambler
Harley Rider
6 REPLIES 6
4x4van
Could also be a malfunctioning blend door.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
JaxDad
midnightsadie wrote:
6 days I,d bet breakfast you have a leak.call your tech back. leaks are hard to find.
Reread the OP, he said he had it worked on last year. It worked 6 days earlier but today it doesn't.
He did not say he had it fixed 6 days ago.
wa8yxm
Possible issues:
Major system leak
Failed compressor
Failed compressor clutch
Failed compressor clutch wiring
Tossed fan belt (Selected vehicle only. My car did this, I also lost power steering, but the Alternator and water pump kept working, on my motor home there is but one belt)
Failed WATER VALVE (heater control valve).. That's one many overlook.
I had a compressor leak, replaced the compressor and all was great.
Ohm I also had a wire fault.. Never did find it, just replaced the wire.
midnightsadie
bullydogs1
Make sure compressor fuse is good..make sure that the fan at the condenser, yet another fuse is also running when you turn AC on..(it is behind one of the rear doors you get at with the soda machine key), also the temp control uses vacuum electric...make sure that is OK and lever is at cold ....make sure compressor didn't lose a belt on the engine (sep belt)...and turns on when AC is on...last is some kind of slow leak....
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
Chris_Bryant
I would guess refrigerant, due to a leak. Though it could be a control problem.
-- Chris Bryant
