โMar-30-2016 06:33 PM
โApr-15-2016 09:26 AM
โApr-08-2016 02:50 PM
RayChez wrote:
I only use the exhaust brake on long down hill grades. I also use it while driving on heavy traffic which tends to come to sudden stops, and it helps slow the coach down faster. Other then those two, I have it turned off.
โApr-08-2016 01:17 PM
โApr-03-2016 06:23 PM
wolfe10 wrote:
If you were in hills/mountains, I am a little concerned that you did not use the exhaust brake.
The service brakes (brake pedal) should NOT, repeat NOT be used for controlling speed of descent on grades. This is true of any heavy vehicle. Brakes turn momentum (ya, a LOT of momentum) into HEAT. Easy to overheat them.
The service brakes are just fine for stopping, but those few seconds are very different than a long downgrade.
Again, suggest you DO get comfortable using the exhaust brake-- it IS your friend.
โApr-03-2016 06:22 PM
โApr-03-2016 03:37 PM
โMar-31-2016 08:34 PM
lakebum wrote:
We just took delivery of a 2009 Coachmen with a turbo Diesel and it has an Engine Exhaust Brake switch and was wondering if it is ok to leave that option on all the time? Are there any pros and cons to leave it on? How does it effect fuel economy? I am at 26500 lbs and I like the extra braking assist
โMar-31-2016 01:31 PM
โMar-31-2016 12:42 PM
โMar-31-2016 06:58 AM
โMar-31-2016 06:45 AM
โMar-31-2016 05:55 AM
โMar-31-2016 04:59 AM
โMar-30-2016 09:15 PM
