Engine overheating
thriftydutch
Can old antifreeze cause the engine to overheat. The tester shows that it is still okay for minus 45 degrees celsius.
1990 L.E.R. Dodge B 250 Class B 17'
19 REPLIES 19
enblethen
When was the thermostat last changed out. It could have failed in partially closed position.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
gbopp
Flush the cooling system. If the antifreeze is old, the radiator may be clogged.
Does the engine overheat quickly? Or can you drive for awhile before it over heats?
It's possible your thermostat is stuck closed if it over heats quickly.
midnightsadie
collapsed hose,, stuck thermostat,, clogged heater core, cooling fan in front of radiator not working.try back flushing the hole system. blown head gasket.
thriftydutch
I already cleaned the radiator fins and combed them straight two months ago.
Road_Runners
You might need to clean out your radiator fins so more air can pass through and flush the water cooling system to allow more water flow.
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
