I will be leaving on an long vacation in a couple of weeks, towing my Honda CR-V along. There will be a couple of stretches of several days when I will have no need to disconnect the car for local driving. Should I disconnect the car daily anyway to exercise it on it's own and go through the gears, or is it safe to leave it connected for towing several days in a row?
As those above, now that we've installed a charge line, back-to-back towing days no longer present a problem. I restart the car and run through the towing procedure at least every 8 hours, but usually more frequently. Easy to do at a fuel stop.
2012 Jayco Embark TB390 Blue Ox Aventa LX Tow Bar 2009 Honda CRV (mini toad) 2014 Ford F-150 4x4 (monster toad) FMCA #F413428
Depending on your braking system you may have to drive it to keep the battery charged. We usually take a drive in the evening to check out the local sights and charge the battery.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis 2010 Subaru Impreza Sedan Camped in 45 states, 7 Provinces and 1 Territory
Have towed my 2006 CRV 4 days without unhooking. I usually start it and let it run while I hook up the cable,water & sewer. In the morning I start it and let it run while I unhook the cable,sewer and water.I always leave the door open so I dont forget that I have it running. follow the instructions in manual to tow then.
Just start the car and run through the towing procedure everyday before leaving. I have done that on numerous trips with the crv in tow and never had a problem Good Luck
