Oct-01-2016 11:12 AM
Oct-10-2016 09:42 AM
Oct-03-2016 04:58 AM
Oct-03-2016 04:40 AM
Oct-02-2016 06:23 AM
Oct-01-2016 11:16 PM
Mandalay Parr wrote:X-2, the DW puts money in savings every month in case anything happens. And it really helps that I bought my coach new 12 years ago.
I have never had one in 12 years. I pay for my own repairs.
Money ahead and no hassles.
Oct-01-2016 05:13 PM
Oct-01-2016 04:56 PM
usersmanual wrote:DownTheAvenue wrote:
Read the actual policy, not the sales brochure. Most extended warranties are very good about wording their policies so things are not covered. Example, "If a non covered part causes a covered part to fail, the covered part will not be covered."
not saying this is not true but have never seen nor heard of such Have you a quote from a policy that says things such as this ?
seems a bit on the odd side at best if such a thing is out there
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Oct-01-2016 04:16 PM
Oct-01-2016 04:15 PM
Oct-01-2016 03:37 PM
Failure of a covered part under normal service. A covered part has failed when it can no longer perform the function for which it was designed solely due to its condition, and not due to the action or inaction of any non-covered parts. In addition, a Failure will be deemed to have occurred when a covered part has worn beyond the manufacturer's tolerances allowed for the particular Vehicle at the odometer reading when the problem occurs.
Oct-01-2016 03:29 PM
Oct-01-2016 03:26 PM
Oct-01-2016 03:20 PM
Oct-01-2016 12:12 PM
Forest66 wrote:
Getting ready to buy a Class A MH. Looking to buy an extended warranty for it as I will be on the road a lot
Who would you recommend using for the warranty if not going thru the dealer. Is it cheaper to buy direct (i assume it is) than going thru the dealer?
Thanks in advance
