โJul-20-2015 02:49 PM
โJul-26-2015 07:23 AM
Racorman wrote:
I'm going to move my starter battery in the MH from under the entry steps to the front of the coach, closer to the starter. It probably will take about 4' of extra battery cable, What is the best way to join the existing battery terminal end to an extension battery cable. Is there some sort of junction box for doing this?
โJul-26-2015 06:54 AM
Racorman wrote:Born To Travel wrote:
I would find the starter relay and measure from there to where the battery will be re-located and go to the auto parts store and get a new cable that length... The longer the cable the more resistance and the less amps there will be for starting.. cables are a common item at the parts store..
I just figure that if this does not work....... I'll buy a bigger starter battery. Money is no object with this rig. We got it for 1/2 price.
โJul-25-2015 09:00 PM
Canadian Rainbirds wrote:roam1 wrote:
If you move it closer, you should figure a way to shorten the cable, not add to it
I agree. One more point for connection corrosion to cause frustrating problems.
โJul-25-2015 08:55 PM
โJul-25-2015 06:54 PM
โJul-25-2015 06:24 PM
โJul-25-2015 05:58 PM
โJul-20-2015 06:06 PM
โJul-20-2015 04:59 PM
โJul-20-2015 04:46 PM
