F53 cruise started working intermittently
spotrot
On the last few days of a 3,000 trip, sometimes my cruise would not engage.
This Ford system does not show an icon on the dash when the system is ON - it only illuminates the icon when it is ON and engaged. Therefore, I don't know which part of the process has the problem.
When it's working, I can use the ON/OFF and engage switches on the steering wheel repeatedly, so it appears not to be the switches.
Plus repeatedly pressing them when it's not working has no effect.
It seems like the cruise didn't work after starting the engine, but after an hour or so of driving, it started working again.
From suggestions to the other cruise post, I'll examine the brake pedal switch -- it is very sensitive.
But other than that, I have no idea where or how to trouble shoot this intermittent problem.
Thanks in advance for any feedback from similar experiences.
8 REPLIES 8
spotrot
Thank you for the posts. Mine is a 2008, and I'm hoping it's just the adjustment of the brake pedal switch.
tderonne
'02 cruise control (speed control in Ford lingo)is different than the '07.
How I fixed mine (an '04)
And someone else's problems with schematics
Tim
2004 Winnebago Adventurer 31Y
Ford chassis
MiRV
I had a very similar problem on my 2002 Itasca Sunova. It all started after I had the front end aligned which lead me to believe it was something in the steering wheel. I took it to have to "worked on" and they replied the servo ($700+). It worked for a short time afterwards and now back to not working. I think I have a shorted wire somewhere…I haven't been able to track down the issue either.
Livin' the Dream, Over the Road
spotrot
All good ideas, Thanks.
I'll re-post if I locate the source of the problem.
Jagtech
I had a customer bring in the steering wheel controls for repair, same intermittent issues. Turned out to be a flakey pushbutton tact switch on the steering wheel internal circuit board. Other than that, a maladjusted or defective brake switch would also cause intermittent problems.
1998 Triple E F53
1995 Jeep Wrangler toad
Golden_HVAC
What year do you have? That would really help out anyone with a answer.
On my 97 chassis, if the 4 way emergency flashers are on, then the CC will not work. Also many vehicles the CC will not work if the fuse for the brakes is not working. Any problems with either of these?
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
tderonne
I think you have an '08? If so, the cruise function is part of the drive by wire system. As such, the only pieces to the system that are unique to the cruise are the switches and wiring. Not too much to check out.
Tim
Ford chassis
2010Liberty
I would suggest you check in with Ford dealership. They have been know to have many cruise related recalls. may or may not affect you but never hurts to know.
