F53 Transmission indicator pointer wrong
TexasH
My Unit is a 2002 Southwind 37U on a 2001 F53 chassis. The tranny indicator above the steering column is off. That is, when it's in drive, the indicator points to Low, and when it's in park, the indicator points to Drive. Anyone know of an easy fix or am I going to have to make a trip to the Ford dealer?
2002 Southwind 37U Ford F53 - V10
2007 Jeep Liberty Toad
7 REPLIES 7
Pirate1
jerseyjim wrote:
Hello, Ford?
Agreed. Seems I am seeing many complaints regarding this, many not involved in the recall. My 06 needed an adjustment too.
TexasH
Thanks for all the responses. I'll get out to the rig this weekend and try to find the adjustment wheel.
OnaQuest
There is an adjustable wheel/nut under the steering column just for that purpose.
Fiesta
If the indicator is on "1" broken cable/parts. If it is off mark use the thumb wheel under the steering column to adjust. Check cable routing for easiest movement.
jerseyjim
Hello, Ford?
Home_Skillet
Simple fix.
The PRNDL indicator has a cable the moves the indicator needle. On the cable there's a plastic retainer with an adjusting nut that breaks.
You just have to replace the PRNDL indicator.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
Mandalay_Parr
Is it an electronic or mechanical indicator?
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
