Fiberglass roofs
Johno02
Our Motor Home has a fiberglass roof, which I really like, as it is all one piece. Do any of the current builders or coaches still have these?? I have seen a lot of damage and failures on the rubber roof, and we ever upgrade, I would like to have fiberglass.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
25 REPLIES 25
Mile_High
I've actually not heard of an problems with MH rubber roofs, but it was always a discussion with fifth wheels. When we had ours, the fear was tree branches, and the haunting air balloon that forms in the front when that front seal lets go. You see them every once in a while on the highway and you know the guy doesn't know its happening.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
dougrainer
Effy wrote:
Personally I haven't seen a lot of failures on TPO roofs and I've seen a lot of RV's. Maybe I am not looking in the same places as the OP. Each roof type has it's merits and shortfalls. TPO is pretty tough stuff but can be damaged easier than fiberglass. That said it's also much easier and cheaper to repair than fiberglass when there is an issue. The fiberglass roofs on some manufacturers are paper thin and recently there have been a rash of winnies with their roofs peeling back in the wind. All roofs require maintenance and care to ensure they don't fail. Given a preference I'd probably prefer fiberglass over TPO, but all I've ever had was TPO and never had an issue. It's a nice to have but I wouldn't make it a deal breaker.
GOOD post. Also, Fiberglass does not fare as well in a bad Hail storm. EPDM/TPO usually will have holes punched in the deck, but the Rubber integrity stays and no leaks except at busted roof vents which will also be busted on Fiberglass. I would prefer Fiberglass, but that is a cost decision. I would not walk away from a Motorhome if all parameters met my criteria and it had a EPDM roof. Doug
Effy
2013 ACE 29.2
JoeH
When I ordered our Newmar, the one piece fiberglass roof was an option, which I got.
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
Ivylog
timmac wrote:
I am on my 3rd RV with rubber roof and no problems yet
Three RVs since 1990 and a 08 currently... looks like you only keep them less than 10 years. Rubber roof seem to start giving problems at 12 to 15 years.
Upgraded with a 08 HR Navigator 45โ€™...
gmctoyman
Foretravel
Dave W. AKA "Toyman"
KE5GOH - On 146.52
RV's ? What RV's ???
Apache Pop-up
Classic GMC Motorhome
07 Leisure Travel Sprinter
Do Boats Count ?
Jim
Pretty sure Mile High is correct.
I've had both types and Eternabond on my '94 helped seal up leaks in the rubber roof, and I've used it on the end cap seams, and will use it along the sidewall seams of my '02 full fiberglass roof.
Thing is that both roof styles have problems and it takes some effort to stay on top of them (heh).
The rubber roofs shrink and tear or get cut. The fiberglass are extra thin and the edge seals or a cut out seal in the roof can fail and wind can get under the roof and rip it right off. I've seen pics here on the forum of fiberglass roofs that were nearly half gone because of wind.
Having had both, I do think the fiberglass is superior, but it's still a maintenance item. I still have the job of running 2" Eternabond along each edge to prevent the roof peeling off in heavy winds.
Here's my blog post about the end cap seam taping...Roof taping...
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
Mile_High
I believe nearly all the Winnebago line is fiberglass.
Viewfinder
Tiffin
timmac
iggyAZ
I think the smaller motorhomes may still use TPO roofs.
I also agree with you about the fiberglass roof. That is what I have on my Forest River Georgetown XL.
2012 Forest River Georgetown XL 378TS
