flex seal
maxbass
I see the ads on tv and wonder if it would work on a motor home...just a thought....
13 REPLIES 13
Pigeon_Man
I noticed you were inquiring about the TV flex seal. My brother said that it is a waste of time and money. I have a 86 Sunland Express,toyota mini and I used the PRO FLEX RV in a caulking gun to seal my seams. I got a bottle cap and put mineral spirits in it and after using the sealant I dipped my middle finger in it and just rubbed the sealant and it made it smooth and feathered out really well. Sure beats silicon sealant, and if needed to be removed in future, would be lots easier.
We have had our mini-motor home since 2009 and have really liked it. Only has 27K miles. I'm on the Toyota camper site too.
eric1514
BobandShaz wrote:
robsouth wrote:
I have not used the clear. I have not used it on an RV. I have used the black elsewhere and it worked very well...for a while, then it seemed to dry up and crack and deteriorate. I will not use it again. Just my experience. Yours may vary.
Same issues on a tin garden shed ๐Ÿ˜ž
Ditto on my rain gutters.
2006 Dynamax Isata IE 250
420 Ah batteries
400w Solar
falconbrother
Flexseal will work for a small leak in a dire emergency. But, get yourself some proper sealant from camping world and save the heartache down the road.
BobandShaz
Bob and Sharon
2006 Winnebago Sightseer 29R Ford F53. Roadmaster Eagle 8000. 2001 Ford F150 7700 4x4. Still shopping for toad brakes. FMCA F286179
pa_traveler
One guy that worked with us used tar in a can on a rubber roof repair. This is wrong it caused it to bubble. Always need to know what product can be used where.
eHoefler
I have made repairs where people have used it in an attempt to fix water leaks ( skylight leak, fresh water leak, and a shower pan leak ), simply, it does not work!! Makes it more difficult to do the correct repair.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
bamcote
Petroleum distillates don't work well on rubber roofs.
DH, DW, Tildie, Bella and
Molly the Maine Coon
and Greta the shorkie pup
2008 Fleetwood Bounder 36Z
2007 Saturn Vue AWD with Ready Brake Brute
brirene
Picked up a can of Rustoleum brand clear spray sealant. I haven't applied it, and don't know if it will be better or worse, but I didn't know that made it until I saw it at Menards. Don't think I'll use it on the rv roof though.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
dan-nickie
Personally I have never had anything advertised on TV to live up to its claims.
Here is one quote from the link above:
"I purchased two cans of flex seal to repair two small leaks in the roof of my fifth wheel rv. After applying the product as directed the roofing material began to bubble and separate. The preliminary estimate to repair the roof is $2800.00"
Dan and Nickie
2014 Forest River Berkshire 390RB
Ka_Ron
You might want to check out some complaints and reviews before you buy Flex Seal.....Scam Book
Does not seem to get very good reviews.
RV_daytrader
trnfla wrote:
I was thinking the same thing since they came out with a clear version. My thought is to tape off and spray over the cab over seams.
RV Proflex has a brushable clear sealer...I used in on all my roof seams before coating the roof with koolseal.
YODA...our lil Toyota!
1989 Toyota Seabreeze
robsouth
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
trnfla
Now 2004 Winnie Minnie 31C
Had 2007 Zeppelin 190 Hybrid,
1999 30' Dutchman Classic FW
