Fresh water tank
126crosby
Tank fills up when using outside hook up. Even with valve ofg
5 REPLIES 5
4x4van
If you get intermittent cycling when using the pump system (no city water hookup), then the problem is likely a bad check valve in the pump. Otherwise, it is likely a leaking fill valve.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
Bumpyroad
the shut off on my bounder was a small brass valve. it had an O ring that had a very tiny slit in it and it would leak water past and back into the tank.
bumpy
1971duster340
Old-Biscuit wrote:
Other possibility is the on-board pump internal check valve is leaking allowing water to back flow thru pump.
It's happened to me. I put a ball valve inline in the pipe from the pump and close it when we are on shore water or open it to use water thru the pump. The pump stopped the intermittent cycling too.
Greg
N5LFH
2007 Chariot
Old-Biscuit
If you have a FILL valve it could be leaking thru or is cracked open
Fresh water tank full.......turn off city water and run the pump using tank.
Flushing water thru could free up/clear pump check valve
FILL valve....open/close it and see if it shuts off better. Otherwise replacement
usersmanual
well the only thing that causes that is the valve is leaking by
replace the diverter valve
