May-25-2015 06:51 AM
May-25-2015 12:47 PM
Executive wrote:
The thermister, that's that small thingy attached to the third or fourth fin inside the fridge at the back, controls the on/off of the fridge. It's simply a thermostat. It's normal for the fridge to come on and go off depending on the temp inside the box. If it runs all the time then the thermister has most likely failed....Dennis
May-25-2015 08:45 AM
May-25-2015 07:11 AM
noleakman wrote:Sounds perfectly normal to me.
I have a Norcold 1200 When you are on propane and the fridge gets cold enough will the burner you can hear go out and when it needs to be colder it comes back on!Some times I can hear mine some time not! The fridge runs about 33 degrees!
May-25-2015 07:10 AM
May-25-2015 07:09 AM
May-25-2015 07:07 AM
May-25-2015 07:04 AM
May-25-2015 06:57 AM
May-25-2015 06:54 AM
