Front End Alignment
ratfink09
Took the advice of many on this forum and had my front aligned on our 2011 E450 Chateau. Big difference. No more sawing steering wheel back and forth. Any one hesitating should go for it!
2 REPLIES 2
ratfink09
Sorry, I do not. After I picked up our RV I thought about someone would ask. Before I took it in, I filled the water tank and it had 3-4 containers of fire wood in the storage bay. Also had a full tank of gas. Go some where that works on heavier trucks also. This shop had a couple of Class C`s, couple of Class A`s and FedEx trucks being worked on.
j-d
GOOD ON YOU!
Do you perchance have a report from the alignment machine showing Before and After Angles for CASTER, CAMBER and TOE?
Many of us would like to see it.
