Jan-08-2020 03:48 PM
Jan-17-2020 08:51 AM
Jan-16-2020 03:26 AM
Jan-15-2020 06:42 PM
myface wrote:Your MH is short probably lighter than many of us that installed the HD Henderson springs.You already ordered the air bags, they will increase your ride height. I would try them first seeing you already paid for them. You really need to know what your front axle weighs, a spring that is too stiff will put a lot more pressure on that upper A arm than it was designed to take, which is only stamped steel and over time can cause fatigue cracks in that arm. Also how are you checking how level your MH sits ?
1.25 and 58.000. I saw a springs for $360 pair with 6000lbs.
Jan-15-2020 03:00 PM
Jan-15-2020 01:51 PM
Jan-15-2020 12:35 PM
Jan-15-2020 09:05 AM
Jan-15-2020 08:04 AM
Jan-15-2020 08:01 AM
Jan-14-2020 02:15 PM
myface wrote:Find a different "guy" to give your money to. Anyone who says that shocks will raise your vehicle is lying or stupid. Your shocks may also be shot, but they will have no effect on ride height, only damping.
I told the guy about the springs and he said that shocks will raise the front.
Jan-13-2020 05:29 AM
Jan-11-2020 12:02 PM
dodge guy wrote:
Hello and welcome.
Shocks do nothing for ride height. That's in he springs. If it is sitting low, the springs are probably worn out. You will need to find the ride height specs and measure from the frame to the ground.
Jan-09-2020 12:12 PM
Jan-09-2020 08:25 AM
