Fuel tank preventitive maintainance
BrianinMichigan
Ok, so I am doing my due diligence and figure I'll pull the fuel tank down and replace the hoses and in tank fuel pump. Well now that it is down I am finding the parts aren't that easy to come by. My main concern is the main fuel line that comes off of the in tank pump. It looks like a short hydraulic line. Does anyone know where to find the parts for this thing? http://i.imgur.com/yhMik5zl.jpg
hose
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS,
CAMPING: WHERE YOU SPEND A SMALL FORTUNE TO LIVE LIKE A HOMELESS PERSON.
5 REPLIES 5
BrianinMichigan
Ok, Hydraulic style fuel hose is made and ready to be picked up. $45 dollars. The fuel hose is fuel injection capable, good for ethanol.@ .25 cents an inch. no problem. Fuel pump, coming in. We'll see if it's the same thing. Boy I can see why it cost so much to have an issue like this repaired on the road.
blazenpm
Brian, I have a question for you. What chassis is your Georgie Boy sitting on. I have a 1989 Fleetwood Bounder that sits on a GM P-30 chassis. I had to do what you did with the fuel tank. I had "Truck Works" in Bannin, Ca. do my fuel tank work, ie.hose replacements, pump, regulator replacements. They found the parts. Their contact info is: 1-951-922-4776. They might be able to assist you.
MountainAir05
go to any auto parts store and get some good Gates fuel line. You are talking about where the tube comes off the pump and it a flex line to the frame then metal toward the engine. Is this what you are looking for
http://www.partsgeek.com/catalog/1990/chevrolet/k3500/fuel_delivery/fuel_line.html
they show they have a 2 different ones but not a good picture. Our Napa store thinks he can order it.
Autopartswarehouse shows many like 50. Working on a computer so need to search time to ensure that it is working. enjoy
http://www.autopartswarehouse.com/search/?Ntt=&Ntk=Main&PN=0+4294868014&N=0&VN=0&Nr=AND%28wpn_tl_name%3AEngine+%26+Drivetrain%2Cwpn_cat_name%3AFuel+Systems+%26+Components%2Cwpn_scat_name%3AFuel+Lines+%26+Components%2Cpart%3AFuel+Line%29&refType=Product+Fit&refValue=Direct+Fit&Npp=50
BrianinMichigan
Dennis, I did not think this worked. I reposted a 2nd post on this.
Moderator please remove
Executive45
Brian, your link doesn't work. Please check it and repost...thanks.
That said, there are places that make hoses to your order. Look in the yellow pages or google hydraulic hoses...Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
