Aug-11-2022 08:57 PM
Sep-03-2022 08:56 PM
Aug-14-2022 12:15 PM
Aug-14-2022 10:53 AM
Freeway Flyer 05 wrote:
Good info all. I was Class B licensed before they came up with all the new rules, so should have no problem with a CDL, if that comes up. (Although I don't expect it to)
The following info is much appreciated, and sort of the way we are going.
I never want a Class C. Before purchasing our current Class A, we looked at used Class Cs and were incredibly disappointed. For example, for similar pricing we found a Class A with greater carrying capacity, more storage, better floorplan, and 50A electrical (2 ACs) -- and levelers (many Class Cs don't have them and they are expensive to add).
I never want another DP (unless I come into a lot of money). Our 2001 Newmar was generally a joy to drive and ride in while our first RV (2004 Sea Breeze) was difficult to drive, loud, and uncomfortable. However, our DP was VERY expensive to repair. Since it was about 20 years old, expensive things (e.g., radiator) needed replacement. Yearly "tune ups" were also pricey.
3rd time's the charm. So far. Our 3rd RV is a 21-year-old, 31-foot, Ford V10, one owner gasser. One owner who didn't drive it much and appears to have kept it in storage when not driving. We lucked out. It's EASY to drive. The V10 has plenty of power. It's comfortable, not an air bag ride, but comfortable. Finally, despite the up front engine, it's not loud. Go figure.
Conclusion: If you can, test drive because YRMV.
Aug-13-2022 09:41 PM
Aug-13-2022 12:01 PM
Aug-13-2022 07:46 AM
Aug-13-2022 05:54 AM
Aug-13-2022 04:24 AM
LouLawrence wrote:
It may exist in some States but not FL, TX or SD (full timers States). TX does require a Class B upgrade for ALL RV's over 26,000# but is in no way related to air brakes.
Aug-12-2022 03:58 PM
Aug-12-2022 03:31 PM
Aug-12-2022 01:47 PM
Aug-12-2022 01:13 PM
rjstractor wrote:blawless wrote:
As was said earlier find the floor plan you like and then if its a gasser fine if a diesel fine. I have a 36' gasser and it has more storage than many diesels of the same size. Only one thing that wasn't mentioned regarding the diesel MH is the Air brakes. You will require an endorsement on your driver's license for the air brakes. This involves taking and passing air brake course before you can legally drive it. Which may or may not delay being able to drive it. In addition if you become sick etc.. (heaven forbid) while you're out and about does your significant other have the endorsement as well to be able to drive it home or to a safe location while on the road.
This unfortunately never gets mentioned in any of the diesel vs gas MH debates.
This never gets mentioned because it's not an issue in the US. I don't know of any state that requires a CDL with the air brake restriction removed to drive a motorhome with air brakes, UNLESS it's for commercial purposes. Maybe it's different where you're from.
Aug-12-2022 01:05 PM
Aug-12-2022 12:38 PM
