Gen oil filter
noleakman
I have a Onan 5.5 Gen and I just checked the last time I changed oil! It has been a year and 8 months and 14 hours! Should I still change oil and filter with that few of hours ??
13 REPLIES 13
Camper_Ken
doc brown wrote:
Absolutely. As said exercise that motor every other week for 1hr under 50% load. Stay with the Onan schedule and do not forget to clean the spark arrestor - many people ignore this!
What does cleaning the spark arrestor do?
Ken
2016 Itasca Navion 24J
Clay_L
One thing to note about changing the oil in the 5.5 JAB Onan is that the second quart goes in real slow.
I do two things to help.
Fill the new filter before installing it (always a good idea anyway I think)
Screw the oil fill cap/stick in and turn the engine over for a few seconds to circulate the oil up into the engine then start adding oil again. I usually have to do that two or three times.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
Matt_Colie
You have gotten answers, but none are complete in my book.
The problem with 20 months and 18 hours is that you ran the engine at all. Combustion by-products are acidic. There are corrosion inhibitors in the lube oil that will go bad with just exposure to air and they get bad even faster with combustion by-products. Even Mobil 1 says one year maximum.
You do not need to change the filter, but it is not much work to remove it and drain it so that contaminated oil is also out of the engine.
Much of the time I worked on shore was doing engine testing.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
w4phj
Absolutely !!!
2021 Winnebago View 24J
2021 Ram pick up
2015 Jeep Wrangler Unlimited Sahara
Ham Radio Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
94fxds
Oil filter is $10 and 2 qts. of oil $10. Very easy to change, why would you not spend $20 every year to maintain the generator.
crasster
I just go with a Wix filter and a synthetic oil. It's been good thus far.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
noleakman
I believe the book says 30 weight in warm climate
doc_brown
Steve,Kathy and Josh
Morpheus(Basenji)at Rainbow Bridge
2004 40' TSDP Country Coach Inspire DaVinci
350 Cummins, 3000 Allison
2014 Jeep Wrangler Unlimited Sport S, Air Force One Braking, Blue Ox
PortWentworthSa
You are absolutely asking for trouble if you don't change the oil and filter after 1 1/2 years. Why would you even consider not doing it?
Doug156
I use the full synthetic oil in mine. I stay with Onan's schedule, but the synthetic oil for more peace of mind. Plus it starts much easier in the cold weather.
Doug & Mary Jane
2014 Bay Star by Newmar
2009 Subaru Toad
Ziggy & Maxi, the hounds
Retired and loving it
gswcgi
Yes, follow the owner's manual and use Onan filters! Onan filters have a low pressure cut off that many after markets filters don't have!
'03 Safari, DP, 36" Nissan 4X4 toad
Triker33
Don't forget to exercise it every month.
I don't use mine much other then exercising it.
So only change it every 36 months.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
turbojimmy
Yes. The manual for my Onan says to change the oil annually or every 150 hours, whichever comes first. I don't know the rationale, but I intend do it (first change was when I first put it on the road a couple of months ago).
1984 Allegro M-31 (Dead Metal)
