Gen-Turi routed past window?
jillhop
I have purchased a Gen-Turi (many of the dog events I plan on attending require them) and unless I have an extensive rerouting of the generator exhaust pipe, the Gen-Turi stack will route over a large window. Is this a safe configuration? I'm not particularly concerned about the cosmetic issue of the pipe running up past the window.
Dog shows, racing and lure coursing with whippets!
My first RV, 1998 Coachmen 22RK, Ford E350 V10 Triton
17 REPLIES 17
pnichols
Yeah ... I realized right after I posted that you were asking relative to RV parking/camping in packed-in situations at dog events.
We use the method I described for our travels in hot weather when parked or camping without others around us. (I came close to buying a Gen-Turi once but decided against it for a couple of reasons.)
2005 E450 Itasca 24V Class C
jillhop
Many of the events I attend require venting of exhaust fumes at or above roof level, because of the number/proximity of rigs. No one wants someone's generator exhaust spewing out right next their set-up. Otherwise, your method of using the fan roof vent sounds like a good one.
pnichols
When we run our generator for air conditioning whenever in the motorhome or whenever gone from the motorhome with the dog left inside, we close up everything except the one roof vent with a reversible 3-speed vent fan in it. We leave this fan set to AIR IN and on it's lowest speed setting. This creates and maintains a small amount of air pressure inside the RV.
This small amount of air pressure keeps any generator fumes from entering the RV anywhere. Since the stock generator exhaust position as installed by Winnebago is way down low, the vent way up on the top of the roof does not pick up any generator fumes while it's maintaining air pressure inside. The cooled air inside the RV always smells fresh and fume-free using this method and no Gen-Turi is required.
In fact, if one's RV air conditioner was to ever have an air circulation "leak" such that some outside air inadvertently got mixed in with the air it circulates in the RV's interior, having a Gen-Turi exhausting up near the top of the RV could in fact cause fumes to wind up inside the RV whenever the air conditioner was running.
tenbear
I made my own Genturi and have used it several times at concerts. Even after running for an hour or two it is not hot. Barely warmer than the side of the MH.
2010 Subaru Impreza Sedan
fortytwo
If it was hot it wasn't a genturi!!! I've seen folks just extend the generator exhaust with plastic pipe. Once I saw that type extension on a bus conversion -- several hours later there was a pile of melted pipe on the ground.
For the genturi to work the smaller exhaust pipe has to be surrounded with a 3-4" plastic pipe centered on it. As the hot exhaust rises it pulls cooler ambient air into the pipe and if working properly the combined air will be cool enough that the plastic pipe is barely warm at about 4 feet up. I made my own 15 years ago for about $10.
Parts list: 90 degree metal electrical conduit of proper inside diameter to fit the generator exhaust.
1 10foot 3" lightweight drain pipe (may need two)
2 4" small diameter bolts
drill a hole in the metal conduit for one of the bolts at the point where the bend ends and a second hole 90 degrees off near the end so the bolts form a cross. Matching holes in the drain pipe complete the construction. I cut my pipe into two 5 foot sections for ease of handling. Drain pipe has one end expanded so a coupler won't be needed.
Wes
"A beach house isn't just real estate. It's a state of mind." Pole Sitter in Douglas Adams MOSTLY HARMLESS
klutchdust
rockhillmanor wrote:
klutchdust wrote:
Quote:"Genturi pipes are NOT hot. That's the whole reason for buying them!""
I beg to differ. At a recent event i touched one on a coach nearby and it was hot. No hotter though than the one I made using similar plastic pipe.
Sure it was a genturi? :W
I have had mine for years and it is not even warm to the touch after running 24 7's.
Looked like all the other ones i have seen that are store bought. Doesn't matter.
rockhillmanor
jillhop
Thanks, everyone--I was thinking about CO/fumes when I made the original post, but I'm glad that the heat issue was brought up--I'll certainly pay attention to that now! Where the exhaust stack will end up is fairly close to one of the roof vents, but further from the Fantastic Fan, so that does bear watching. Thanks for all the input!
klutchdust
ronfisherman
Moderator
Moderator
Current Gen-turi instructions state to make sure that end of Gen-turi extends 6" above roof. RV AC units do not circulate outside air into RV. There should be no problem with fumes. Open vents could be a problem. Here is a link to instruction from Camco posted on Amazon. You will have to scroll down the page for instruction and compatibility info.
Since my Class C is higher than normal C's. I have the 18" extension. It helps to keep fumes away from all vents.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
rockhillmanor
gbopp wrote:
I thought the OP was concerned about fumes falling into the window. I didn't realize the concern was the heat from the Gen-Turi damaging the window. :E
Posted By-jillhop I have purchased a Gen-Turi (many of the dog events I plan on attending require them) and unless I have an extensive rerouting of the generator exhaust pipe, the Gen-Turi stack will route over a large window. Is this a safe configuration? I'm not particularly concerned about the cosmetic issue of the pipe running up past the window.
Mine runs up the side of my window also. No problem the exhaust is well over the top of the MH. Have never smelled exhaust even on the most windy day.
What you DO have to watch for is if it runs up parallel to your AC unit then you have to reroute it. Which is nothing more than an additional pipe. This is show in the directions that come with it.
Welcome to the forum! :C
I show dogs also. I just wish ALL dog shows that don't have hookups would require exhaust stacks.:W
tenbear
You could be right, the OP never did say what his concern was. In any case Genturis are supposed to extend above the roof line. Shouldn't be any problem with fumes. I haven't smelled any fumes in the couple of years I have used mine, window open or closed.
gbopp
hmknightnc
As long as it is not an emergency escape window and you have a decent air gap between pipe and window to prevent any possible heating of the window it will be fine
