โDec-10-2013 06:42 AM
โDec-18-2013 03:58 PM
โDec-18-2013 01:25 PM
dougrainer wrote:
What is the actual voltage from the Genset? Do NOT say 120, state the actual digital read out voltage. Doug
โDec-12-2013 05:35 PM
โDec-10-2013 03:23 PM
โDec-10-2013 01:08 PM
โDec-10-2013 09:39 AM
Bud
USAF Retired
Pace Arrow
โDec-10-2013 08:01 AM
โDec-10-2013 08:00 AM
โDec-10-2013 07:57 AM
mfox20 wrote:
Could be the voltage regulator. Had same symptoms on a Onan 5000 a couple of years ago and that was the fix.
If you post the brand, size/model number you will get a lot of good troubleshooting tips.
โDec-10-2013 07:56 AM
enblethen wrote:
When you checked for incoming power to the transfer switch from the genset, did you read two legs of 120 volts to the neutral from the genset?
Did you check for two legs of 120 volts leaving the transfer switch going to the 120 volt distribution panel?
What is make and model of genset. Is it 120/240 or two legs of 120?
Does the rig have an energy management system?
โDec-10-2013 07:38 AM
Bud
USAF Retired
Pace Arrow
โDec-10-2013 07:37 AM
